Question About A 20amp Popping On Me. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-01-2010, 01:47 PM   #16
Licensed electrician
Rewards Points: 3,654
Originally Posted by AlDaja View Post
The meter is at the Main. It is also as I stated a overhead service (not underground). City code for my area allows for either under or overhead to detached garage/out buildings. The original wiring that was used was a 16 guage - 7 strands of it in a coaxial. Apparently, they no longer sell this. So I spliced with a #4 from overhead to the garage, as the original electrician did from my Main (at the house) to the overhead.
Sixteen gauge wire to feed and outbuilding does not sound correct. #16 would be used in something like a lamp cord.
Old 04-01-2010, 01:54 PM   #17
Master Electrician
i think what he's trying to say is that it's a 7 strand wire. each strand is 16 gauge or something along those lines as a 7/16 isn't big enough for number 4 i don't think. coud be wrong though.
andrew79 is offline   Reply With Quote
Old 04-01-2010, 04:14 PM   #18
Thanks everyone for your assistance. I figured it couldn't be my wiring as I actually did it correct into the box versus the hodgepodge that was there by whomever owned the house before me. Because I wired correctly, I figured the breaker was now doing its job and tripping due to something down the line. I discovered a rocker switch that was wired incorrectly (had the neural and black tied into the rocker switch) that feed a security light. The switch when flipped off acted like an interrupter and triggered the 20 amp breaker. So I wired it (with both blacks going into the switch) and the neutral separate and now it acts like an on/off for the light...which is weird cause that's how it worked before. anyway, everything is working great. I left the side of my garage that I typically plug in power tools/compressor on the 20 amp and split the other two lines that are just for lighting and extra receptacles on to their own 15 Amp breakers.
Edit: Andrew, yeah. The original wiring had 7 strands of 16 gauge wire bundled together.
AlDaja is offline   Reply With Quote
Old 04-01-2010, 07:19 PM   #19
Electrical Contractor
kbsparky's Avatar
....The original wiring had 7 strands of 16 gauge wire bundled together.
A #8 stranded wire with 7 strands would closely resemble this.
#16 wire cross-section area = 1.31 mm
#8 wire consists of 7 strands, 1.23mm each
I dare anyone to tell me that they can see the .08mm difference without a micrometer.
-KB
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Breaker Question timchi29 Electrical 6 03-07-2009 06:33 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
