PVC Conduit Reducer - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 05-03-2018, 07:45 PM   #1
Rewards Points: 14
PVC conduit reducer
Hello, I have been looking online for a PVC conduit reducer fitting that will adapt underground 1 1/2 (1.5) inch PVC to 3/4 (or 1 inch) PVC and have not been able to find any products for these sizes. Does anyone know if such a size reducer exists, or alternatively another product I can use to adapt this for. My garage has 1 1/2 inch PVC coming through the concrete floor from underground and I want to transition it to 3/4 or 1 inch PVC underground. Thanks!
kdrymer is offline   Reply With Quote
Old 05-03-2018, 07:59 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 890
Re: PVC conduit reducer
The fitting is called a swedge reducer but I don't believe they come in that small a size. Use a junction box.
Sent from my RCT6213W22 using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 05-03-2018, 08:20 PM   #3
Master Electrician
Rewards Points: 5,374
Reducing bushings and couplings are available in a myriad of size combinations.
brric is offline   Reply With Quote
Old 05-03-2018, 08:37 PM   #4
Licensed electrician
Rewards Points: 3,842
Why can't you go all the way to the panel with the larger conduit ?
J. V. likes this.
Old 05-04-2018, 05:24 AM   #5
Rewards Points: 14
I could, just didn't want to drill a larger hole into the house (to main panel) than necessary. I didn't install the 1.5 inch PVC from the garage, so that wouldn't have been my first choice if I had installed it, but I don't want to rip it out of the concrete.
Old 05-04-2018, 05:44 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 890
You can't use a reducing bushing in the middle of a conduit run. How would you pull thru it?
Old 05-04-2018, 05:50 AM   #7
hkstroud's Avatar
Rewards Points: 6,694
https://www.homedepot.com/p/1-1-2-in...2223/202043291
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 05-04-2018, 07:48 AM   #8
Rewards Points: 14
That link doesn't indicate what it reduces to?
Old 05-04-2018, 07:58 AM   #9
CodeMatters's Avatar
Rewards Points: 7,976
Never seen a reducer used and wouldn't do so. I'd change sizes at a pull box.
J. V. likes this.
CodeMatters is offline   Reply With Quote
Old 05-04-2018, 08:02 AM   #10
Installing the reducer will limit any future changes . I would leave it full size all the way and keep the flexibility to run larger conductors .
Old 05-04-2018, 09:15 AM   #11
Rewards Points: 14
So can I reduce at the conduit body i.e. at this location? : https://www.homedepot.com/p/Carlon-3...-CTN/100404084
I'll have more questions about doing the entire install but wanted to get this relatively minor concerned addressed first before I begin trenching.
Old 05-04-2018, 10:08 AM   #12
A "Handy Husband"
rjniles's Avatar
Rewards Points: 890
You would have to use a 1.5" conduit body and reduce to a smaller size. You cannot bury or make the conduit body inaccessable.
Sent from my Moto E (4) Plus using Tapatalk
Old 05-04-2018, 10:40 AM   #13
J. V.'s Avatar
Rewards Points: 580
Just continue on with the size you have. There may come a day you realize all these guys are right.
Besides, how much more work is it to make a 3/4" opening verses a 1.5"?
Forget the reducer.
Jim Port likes this.
If it worked before you worked on it. You did something wrong.
Old 05-04-2018, 11:59 AM   #14
Rewards Points: 14
Thanks everyone for the input. Would something like the following work?
I would run the existing 1 1/2 inch pvc conduit underground and then when it comes above ground before entering the building I will connect it to a 1 1/2 inch conduit body, and the other end of the conduit body (going in to the building) could have the below reducer on it to transition to 1 inch pvc?
https://www.homedepot.com/p/Carlon-1...-CAR/202077365
Old 05-04-2018, 12:31 PM   #15
Rewards Points: 88
It REALLY helps those replying on DIY, if they can understand just from reading text when no pics are posted, WHAT the person asking for help is doing on their project. Now we have confusing instructions in the above red. IS the 1.5 in PVC already ran UG and then up through the garage floor presently OR is it yet to be installed ?
Gregsoldtruck79 is offline   Reply With Quote
Does flexible conduit just not work? JonInColorado Electrical 5 07-16-2017 07:48 PM
Using 2" PVC electrical conduit RonLNY Electrical 7 01-06-2013 10:34 PM
Conduit Attached to Exterior Foundation rjschwar Electrical 0 07-14-2012 02:14 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
