Punctured Neutral Wire, Repairable? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-03-2014, 05:00 PM   #16
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,112
If the copper is undamaged, tape the conductor then tape the sheath. The cable does not have to be replaced. If the copper is damaged it will have to be spliced or replace the cable.
All responses based on the 2014 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-03-2014, 08:16 PM   #17
Rewards Points: 1,820
You have to be MIGHTY strong to cut through both the sheathing on 12 gauge wire and the covering on the neutral wire by pulling it against a nail! So is it 12 or 14? Ron
ront02769 is offline   Reply With Quote
Old 08-03-2014, 09:09 PM   #18
Rewards Points: 6,652
Do not have to be that strong. Seen it happen a lot of time on everything up to #6. It just takes people not paying attention to what they are doing, when pulling wire.
Old 08-04-2014, 08:08 AM   #19
electures's Avatar
I've wired thousands of houses during my career. Pulled cable across gang nailers, nails, duct work and you name it. Skinned back the sheathing and/or the conductor to the bare conductor. Sometimes I replaced the cable. Other times I taped up the conductor and/sheath with 600v electrical tape. I try and use the same color as the sheath so it doesn't stand out.
Connecting timer with no neutral wire in box miaclockman Electrical 16 06-13-2013 04:57 PM
Neutral wire size? daythunder Electrical 5 06-04-2012 03:32 PM
breakers with multi wire branch circuit (shared neutral) corman Electrical 0 09-10-2011 11:52 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
