Punctured Neutral Wire, Repairable? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2014, 01:16 PM   #1
Rewards Points: 160
Punctured neutral wire, repairable?
Im running new 20AMP circuit to have more outlets in the garage. I currently only have one 15AMP outlet. When I was pulling the wire it got caught on a nail and ripped the sheath and part of the insulation of he neutral wire insulation. It this repairable or Im I going to have to install a junction box to splice the wiring?
I did see a product on amazon for cable jacket repair tape. http://www.amazon.com/Scotch-Cable-J...+jacket+repair
I just wanted to know what the pros would do in my case. Thanks
word2yamutha is offline   Reply With Quote
Old 08-01-2014, 01:21 PM   #2
Hi waiting for this answer
susandd is offline   Reply With Quote
Old 08-01-2014, 01:27 PM   #3
Rewards Points: 3,396
How bad is it?
Biggest issue to me is did you knick the copper.
If copper ok. Tape it up.
If copper not ok. Splice or replace.
Regular electric tape. Not the stuff in your link
ritelec is offline   Reply With Quote
Old 08-01-2014, 02:11 PM   #4
Rewards Points: 6,652
Pull it out and re-run it again. Be a little more careful pulling it.
The Following User Says Thank You to gregzoll For This Useful Post:
ritelec (08-01-2014)
Old 08-01-2014, 02:16 PM   #5
Rewards Points: 1,910
Originally Posted by ritelec View Post
How bad is it?
Do you have a preferred electrical tape for this type of repair? When I walk into the electrical aisle there are about twenty different variations it seems.
Old 08-01-2014, 02:18 PM   #6
garlicbreath's Avatar
Rewards Points: 150
Super 88
Sent from my Motorola MicroTAC 9800X
garlicbreath is offline   Reply With Quote
The Following 2 Users Say Thank You to garlicbreath For This Useful Post:
bcgfdc3 (08-02-2014), jbfan (08-01-2014)
Old 08-01-2014, 02:43 PM   #7
Rewards Points: 1,052
99.9% of the time just wrapping the wire and then the cable with electrical tape will be fine.
However, I would replace it. I am just not comfortable doing something so conspicuously wrong.
Toller is offline   Reply With Quote
Old 08-01-2014, 03:50 PM   #8
Rewards Points: 160
well the good news is the copper wasn't hit. Whats the difference between super 88 electrical tape vs the other brands? Also, what kind of effect does having a knick in the copper make? Im just curious.
Old 08-01-2014, 04:20 PM   #9
Oso954's Avatar
Rewards Points: 364
The performance specs on $4 a roll tape beat the hell out of 69 cent a roll tape.
I like 3M super 33+ tape for most uses. Super 88 is 1 mil thicker, so they claim a better abrasion resistance. Either of them offer superior adhesion as compared to many tapes. They leave far less residue than cheaper tapes, if you have to remove them.
Superior installation temp range, withstand more higher operating temps, better flame resistance and UV protection, etc.
That doesn't mean you will not find other tapes that will work for what you are doing, but you asked about a preferred tape.
Oso954 is offline   Reply With Quote
Old 08-01-2014, 05:52 PM   #10
Rewards Points: 150
perform a test. Knick a piece and bend it back and forth a few times. Do the same with a clean piece.
Super 88 or 33+ are the best. Only used a couple feet when I rewired my entire house. 2000' of nm wired pulled all new fixtures and outlets. You really don't need tape when working on electical unless you have unusual circumstances.
Many many threads arguing the use of e-tape.
If it was knicked the proper thing to do in your case is pull a new cable.
Old 08-01-2014, 06:20 PM   #11
Rewards Points: 160
Well I'd rather not run all new line so I guess I'll go ahead and splice the connection. Thanks for the info guys
Old 08-02-2014, 12:15 PM   #12
Rewards Points: 32
Splice at a
Minimum or re-run. You could tape, save money and time, and create a real issue. Dont fool around with that
ivanjay205 is offline   Reply With Quote
Old 08-02-2014, 02:04 PM   #13
Oso954's Avatar
Rewards Points: 364
In a garage, I would think about putting in an extra receptacle rather than a junction box and splicing. It is rare to have too many receptacles in a garage.
Old 08-02-2014, 04:16 PM   #14
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
OK, haven't seen any question about wire gauge. 15 amp circuit = 14 gauge. 20 amp requires 12 gauge.
What is your wire size currently?
Gregg M.
gmaint is offline   Reply With Quote
Old 08-02-2014, 04:47 PM   #15
Rewards Points: 32
Also not sure about your area but most require gfci in garage
Connecting timer with no neutral wire in box miaclockman Electrical 16 06-13-2013 05:57 PM
Neutral wire size? daythunder Electrical 5 06-04-2012 04:32 PM
breakers with multi wire branch circuit (shared neutral) corman Electrical 0 09-11-2011 12:52 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
