Pump Relay - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-05-2010, 01:20 PM   #16
If you manually plunge the relay down, what happens? What is the volt reading at the coil? If you unhook the pump feeds from the relay, will it still buzz?
fpeftw is offline   Reply With Quote
Old 06-05-2010, 01:25 PM   #17
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from the part number given previously, this is a closed relay. No means to manually activate it.
Old 06-06-2010, 07:39 PM   #18
Originally Posted by roger2386 View Post
Specifically it is an OMRON 24 volt DC/240 voltAC relay G7L2a TUBJ CB!
This is in a control box for may irrigation system. It has never buzzed before and the pump has always started.
Usually irrigation controllers are 24 vac not 24 volt dc, or at least I never saw a dc one.
regularguy is offline   Reply With Quote
Old 06-06-2010, 07:43 PM   #19
nap
You talking to me?
nap's Avatar
I would tend to agree and running ac current through an dc relay would do something such as what is happening BUT op says it has worked before with the current relay.
Old 06-10-2010, 12:36 PM   #20
From your most appreciated relpies, I find that my description of the problem needs clarified. I have a 2hp Goulds pump. The irrigations system has a box on the power pole that controls the pump. It has a relay. This relay is buzzing, but pump is not getting powered up. Secondly the motor on the ground has a set of points which looked burnt. I took them off and the contacts did not look good. I filed the points and am going to put them back on and retry the system. I have called a repair outfit and when I tried to buy a new set of points at a local outlet, they told me that the repair guy had been in and bought a set of points. WAhen I checked with the repair guy, he said he di NOT buy a set of points for MY pump, but did have one of his guys get a set of points for another customer. While my points looked poor, I can not see why they would not make the pump start if every thing else is working properly. whadayathink?
roger2386 is offline   Reply With Quote
Old 06-10-2010, 12:39 PM   #21
I have not idea. I don't work on anything, especially 220 with the power on, I have just enough knowledge to get myself in deep do do. The pump repair guy I called will hopefully check this out. Thanks so much for all your respnses.
Roger
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Configure an add-on radiator as stage 1 heat using a Honeywell thermostat hermhart7 HVAC 10 04-28-2010 05:39 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Irrigation pump relay RHR Electrical 5 08-23-2009 12:16 AM
Irrigation pump relay rdy2go Electrical 2 06-01-2009 09:42 PM
