Pulling New Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2009, 08:43 AM   #1
Pulling New Wiring
How do I get new wiring through this to put in new lighting in my stairwell?
Notch it?
skyhigh82 is offline   Reply With Quote
Old 06-13-2009, 09:09 AM   #2
Rewards Points: 2,350
Carve a groove big enough for the cable, then protect its whole length with nail plates.
Old 06-13-2009, 09:56 AM   #3
The right hand end near the corner shows an offset for the 2 x 10, is there a hollow spot behind it or is it snug to another 2 x 10 behind? Is there enough space to feed between
Chemist1961 is offline   Reply With Quote
Old 06-13-2009, 10:04 AM   #4
It's
snug to the 2x10...no space. Butts up against 2x4 running perpendicular to it.
Old 06-13-2009, 10:15 AM   #5
Oh, well... In that case, carve a groove big enough to lay the wire in and protect its whole length with mail plates.
Old 06-13-2009, 10:19 AM   #6
Journeyman Wireman
Rewards Points: 150
Drill through them using an 18" long 1/2" augur bit. That size hole will take 1 cable. Or use a 7/8" augur bit if you have 2 cables to run.
Jupe Blue is offline   Reply With Quote
Old 06-13-2009, 10:26 AM   #7
Only need to run 1 wire for now but while I'm here going to run 2...you never know
Old 06-13-2009, 06:10 PM   #8
Licensed Pro
Carve a groove and nail plates. Wait... somebody already said that.
Old 06-13-2009, 06:23 PM   #9
Thanks....this is what it did
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
