Protecting Wires Running Into A Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 09:02 PM   #1
Rewards Points: 79
Protecting wires running into a panel
I'm getting ready to install a sub panel in the basement. Planning on installing the panel on a 4x4 piece of plywood so I've got room to manage the wires going into the panel nicely.
Just wondering if I need to do something to cover or protect the wires attached to that board as they're running into the panel?
Thanks,
Mike
tigereye is offline   Reply With Quote
Old 11-22-2009, 09:19 PM   #2
I've never covered or protected the wires going into the panel
If going in the side I try to keep them within 8" of the panel
I try to have most of mine go in thru the top - out of the way
Old 11-22-2009, 09:39 PM   #3
Thumbs up
But for some receptacle circuits it would be more convenient to enter the panel through the knockouts in the bottom. Also, to the OP. There may not be a specific rule (in the NEC) about covering the wires, (because the sheathing is good enough protection against injury. But there certainly is a regulation about how close to the panel the fastener has to be applied (whether it is cable or pipe.) The devil is in the details (So the saying goes)!
spark plug is offline   Reply With Quote
Old 11-22-2009, 09:55 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
Just make sure you use the fasteners so the cable is tight when it enters the panel and not dangling around in the hole.
Old 11-22-2009, 10:08 PM   #5
But not too tight
wires too short in panel / loadcenter houselost Electrical 14 06-05-2009 07:56 PM
Wires leaving panel box orange Electrical 6 05-19-2009 02:36 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
