Proper Way To Splice Simple Standed Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 05-02-2010, 07:37 AM   #1
proper way to splice simple standed wire
hi guys new to the site, just a newbie, amateur DIY guy.... I was wondering how do you pros properly splice simple stranded wire before you put a wire nut on. do you guys use your hands to twist it together and then put your linesmans on it for the last twist .... or do you guys use linesmans for the all the twists? seems like using linesmans for all twists is a pain as the wires fray out to much
thanks
SPEED3 is offline   Reply With Quote
Old 05-02-2010, 08:05 AM   #2
Rewards Points: 2,800
I don't twist stranded wire all that tight. But the individual strands in wire like THHN are too thick for me to twist with bare fingers so I have to get out pliers (usually long nose since I usually have that most handy).
I will give round wire nuts a final half or quarter turn using pliers but only go finger tight with finned wire nuts.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 05-02-2010, 10:40 AM   #3
Rewards Points: 308
With wire nuts and wing nuts, pre-twisting is not required. Especially with stranded. Line the stripped wire ends together and install the wire nut twisting clockwise. That's how they were designed to be used. No taping wire nuts either.
You can twist and tape if you like, but you did ask for a professional opinion.
SImple Simple Dishwasher and Garbage Disposal Connection tabasco Electrical 2 08-06-2009 10:13 PM
Real Basic Electrical question re: neutral wire hellothere123 Electrical 22 07-21-2009 06:07 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
Simple question - proper direction of ceiling insulation jizzle Building & Construction 2 01-07-2009 09:08 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
