Proper Way To Change Direction - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2016, 01:19 PM   #1
Rewards Points: 8
Proper way to change direction
I am wiring for some pot lights. I am running 14-2 wire from the first pot light back to the switch. The ceiling joists run perpendicular to the switch wall. I bored through the ceiling joists from the pot light and now my wire needs to make a 90* turn to go to the switch. My question is how to support this wire in the joist bay properly. In other words, can I staple the wire onto the opposite joist from where the wire came in (bored hole) and then run the wire to the switch.
PS: I didn't just run the wire from the pot light in the same joist bay because the wall that the switch is on is where a lot of heating ducts and plumbing stacks live.
edee_em is offline   Reply With Quote
Old 04-29-2016, 02:23 PM   #2
Rewards Points: 1,076
Re: Proper way to change direction
Stapling it in place is fine.
spaceman spif is offline   Reply With Quote
Old 04-29-2016, 03:12 PM   #3
Btw, you might want to look up any local codes to see if they have specific guidelines for where you drill your holes in the joists and how high above the bottom of the joist that you run your wire.
Old 04-29-2016, 04:39 PM   #4
JUSTA MEMBER
Rewards Points: 3,986
Stapling as describes is acceptable.
Did you install a shield over each joist where you drilled , to prevent someone in the future from nailing up into a wire?
ED
de-nagorg is offline   Reply With Quote
Old 04-29-2016, 08:17 PM   #5
Rewards Points: 8
The holes were bored in the middle of the joists putting them 3-4" above the bottom of the joist. No shields required. Good point, though.
Thanks guys!
Old 04-29-2016, 08:38 PM   #6
Rewards Points: 516
Take the length of the joist, divide it into three equal lengths, don't drill in the center third. That's the standard for structural integrity AFAIK.
Arrow3030 is offline   Reply With Quote
180 Degree Direction Change...Help! New To This Plumbing 14 01-30-2014 08:07 PM
How to switch rotation direction of an AC motor? ChengLaw Electrical 10 10-30-2013 11:51 PM
Change swing direction of french doors tozier9 Windows and Doors 7 09-08-2013 11:57 AM
Vinyl Plank Direction OhioDon Flooring 1 08-20-2013 10:19 PM
