Proper Junction Box For Addition - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2017, 05:21 PM   #1
Proper junction box for addition
Working on a house that had an addition put on in the mid 90's. The new service panel is located in the basement of the addition. Looks like they tied in the old part of the house in an existing box with electrical tape and caps
What would be a proper box to use to junction all these wires properly?
tonepaq is offline   Reply With Quote
Old 05-21-2017, 05:27 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 22,662
Re: Proper junction box for addition
That box is fine if it has a cover.
Old 05-21-2017, 05:40 PM   #3
Whats the proper connections for the heavier gauge wires in there? Im guessing the electrical tape isn't up to code?
Old 05-21-2017, 07:56 PM   #4
Super Moderator
joed's Avatar
The only problem I see i the large ground that is not connected and may not need to be if it goes to the rods. That connection should be in the main panel.
Old 05-21-2017, 07:59 PM   #5
Oso954's Avatar
Rewards Points: 1,330
The heavy wires at the top have a split bolt connection that is taped to insulate the bolt/connection.
Oso954 is online now   Reply With Quote
Old 05-21-2017, 08:39 PM   #6
Licensed electrician
Rewards Points: 3,592
Anyone think the ground is touching the aluminum in the one lug?
Old 05-22-2017, 07:37 AM   #7
Rewards Points: 398
Something else that caught my attention in this "jbox" set up.
The incoming 2 legs and braided neutral on the left top side. The neutral braid is in a lug and the outgoing power there are two legs going out but with what seems to be a bare solid copper wire (in the lug with the braided neutral conductor) being used as the neutral going out instead of a braided or proper conductor to be used as a neutral.
afjes2015 is offline   Reply With Quote
Is difference between ceiling and attic for junction boxes? Mallethead Electrical 13 05-06-2013 08:20 PM
Junction Box Wire Splice - 3-way switch GuitarDude Electrical 4 10-25-2012 12:41 AM
Use the junction box in a can light to pass through another circuit j_sun Electrical 8 09-07-2012 02:47 PM
Junction box and light switches travesty Electrical 3 01-18-2011 01:49 PM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
