Proper Connection Of 220 Circuit To Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2017, 12:08 PM   #1
Rewards Points: 62
Proper connection of 220 Circuit to Panel
Hello,
I'm trying to get my breaker panel up to snuff for a rough inspection on a new bathroom I'm adding. there is only one 220V branch circuit, for the dryer. The wire coming into the panel has 2 "hot" wires attached to the 2-pole breaker, and a braided aluminum ground wire. Like other existing circuits in my panel, the braided ground is clamped to the panel enclosure. I'm told for current code, the grounds have to be run to the ground bus bar within the panel. How can I safely extend this aluminum braid to the ground bus bar in the box?
drfeno is offline   Reply With Quote
Old 11-14-2017, 12:44 PM   #2
Rewards Points: 1,080
Re: Proper connection of 220 Circuit to Panel
They make a connector with 2 set screws for that.
Wilbits is offline   Reply With Quote
Old 11-14-2017, 12:47 PM   #3
47_47's Avatar
Rewards Points: 320
Take a picture showing where the ground is attached and of the inside of the panel.
47_47 is offline   Reply With Quote
Old 11-14-2017, 01:20 PM   #4
Oso954's Avatar
Rewards Points: 1,808
In the older 3 wire dryer circuits, that 3rd wire is a neutral, not a ground.
Oso954 is online now   Reply With Quote
Old 11-15-2017, 07:41 AM   #5
Rewards Points: 62
Sorry, forgot to take a picture of it last night (busy with kids).
Help with new 220V sub panel circuit darkbreeze Electrical 78 12-02-2012 01:15 AM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 07:24 AM
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Bad connection at panel box. today Electrical 8 10-27-2007 11:22 PM
