Programmable Thermostat - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 05:55 PM   #1
How do I install a double pole thermostat in a single pole application?
I have 8 honeywell linevoltPRO 8000 programmable thermostat for my electric baseboard heaters. The trouble is it has 4 wires/double pole and the connection is for a 2 wire/ single pole . how could i get it to work?
could i cut the two wires from the thermostate. A friend of mine bought me them for a gift. Could I still use them for a two wire connection?
Thank You
rex78295
2 threads on same issue merged
rex78295 is offline   Reply With Quote
Old 07-26-2010, 07:23 PM   #2
dSilanskas's Avatar
Double pole tstat?
dSilanskas is offline   Reply With Quote
Old 07-28-2010, 11:23 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 3,620
Each pole has two wires, just like your old thermostat. Just wire it with one pole and ignore the other. There's no need to cut the unused wires off, just leave them alone. Alternatively, you can wire both poles in parallel. This is the better solution because it divides the current equally between the two poles, reducing wear on the contacts.
mpoulton is offline   Reply With Quote
Old 07-28-2010, 11:51 AM   #4
Are you sure your baseboard heater is only 120V. Most are 240. If 240 you should use a two pole tstat to switch both hots.
SleepyDog is offline   Reply With Quote
Line Voltage Programmable Thermostat for Off-peak studhauler Electrical 4 05-11-2010 04:38 PM
Programmable thermostat with a wireless sensor? scraig HVAC 4 02-24-2010 10:22 PM
Programmable Thermostat Suggestions... monkeystomach HVAC 5 02-05-2010 04:07 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 10:02 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 03:57 PM
