Problems With Furnace Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 07:56 PM   #1
Problems with furnace breaker
Everytime my furnace kicks on I will get a buzz out of my breaker box and I will lose power to my electrical outlets in my living room, garage, and I will lose power to my stove. So I replaced the breaker for the furnace and checked all the other breakers to make sure that there wasn't any more burnt up. Then this evening I was in the garage and when the furnace kicked on sparks shot out of the breaker. None of the breakers are warm or hot to the touch. The breaker didn't trip when this happened and I'm out of ideas. I appreciate any insights to this issue. Thanks
gregschrader is offline   Reply With Quote
Old 11-21-2010, 09:24 PM   #2
I=E/R
a7ecorsair's Avatar
Are we to assume that this furnace is electric?
a7ecorsair is offline   Reply With Quote
Old 11-21-2010, 09:47 PM   #3
" Euro " electrician
frenchelectrican's Avatar
If you have large electric furance or heat pump with back up electric heat possiblty you may have a loose connetion.
This need to be address right away before something else will damage.
If it is main brekaer area best to stop right there and call in electrician they can able do this due the safety issue.
and many electric furance do draw a quite bit of current all it depending on size of unit itself.
Merci,
Marc
Old 11-22-2010, 09:14 AM   #4
Mad Scientist
Did you get a good look at the buss bars where the furnace breaker was attached? Many times a bad connection at the buss will burn up the breaker and the buss stabs it was clipped on to. Take a look, and if it looks damaged, you might have to move the breaker to another slot.
Are you sure the sparks came from the furnace breaker, though? From your comment about losing power to other things when you'd hear the arcing, I really think you have a loose connection at the main breaker, and should probably get an electrician to check it out.
McSteve is offline   Reply With Quote
Electric furnace blowing breaker burnt03 HVAC 27 01-04-2011 08:50 PM
Lennox ghr26 furnace problems wayfis HVAC 8 01-05-2010 05:51 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
furnace problems munkee HVAC 2 10-19-2008 07:24 PM
Breaker Problems tonymull Electrical 12 03-30-2005 04:11 PM
