Problem With GFI Plug - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2009, 11:23 AM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Yes thats a possibility but a grounded neutral must have current flow. Without a load operating there will be no current flow on the neutral unless it is faulted to a hot wire. If the neutral was faulted to ground nothing would happen at the gfci when power was restored because there is no current flow till a load operates. If the gfci was tripping when he turned on a load I would say you are correct but it trips only when that ground is connected and under no load on the branch circuit. So what I'm saying is without load on the branch circuit the hot wire has to be faulted. It may be that the neutral and ground and hot are all involved. But the breaker is holding so whatever the hot is faulted to is very suttle.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 07-20-2009, 11:28 AM   #17
I hate speculating with soooo many questions.
It's going to one of those "that would have been nice to know" things
I still don't know if it's a fuse or a breaker.
I do know that:
A) It's not a newer/stock installation because the HR would go directly to bathroom #1 first.
B) A neutral to ground short on the line side wouldn't affect it.
When you get back to it, check the line VS load wiring.
Line = power in, load = power out
220/221 is offline   Reply With Quote
Old 07-20-2009, 07:12 PM   #18
Speculating (to the nTH degree)
At this point, we're all speculating to the n-th. Degree. We might as well be on Wall Street. Certainly, there is incomplete information here. Most likely, the branch circuit extends beyond the bathroom receptacle. Assuming that is the case, there might be a load albeit a small one somewhere along the line. On a more practical level, jdf... needs to do some Continuity testing on all parts of the circuit. That'll reveal where the unwanted conductivity is! (No Matter What)Don't Drink and Drive!!!
spark plug is offline   Reply With Quote
Old 07-20-2009, 08:18 PM   #19
Bad GFCI?
Old 07-20-2009, 08:40 PM   #20
UAW SKILLED TRADES
Stubbie's Avatar
Not likely... the OP replaced one he thought was bad and the new one is also tripping out....at least that is how it appears on the surface.
As 220/221 and spark plug have said more details will help but I don't think we are speculating that much if the results given by the OP are correct.
Stubbie
Blown-in cellulose--holes not plugged: problem? pjp9543 Building & Construction 3 08-16-2008 08:08 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 09:03 PM
