Problem With Christams Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 08:16 PM   #1
problem with christams lights
I have some Christmas tree lights and one of the sockets of the bulb is damaged (squished) causing the lights on the string to be out. There are three wires going into the sockets and if I cut out three wires feeding the socket and just bring them all into a wire nut, will that be OK? It's one of the artificial trees that have the lights attached to them so unfortunately is in not just a matter of getting a new string.
Thanks.
timchi29 is offline   Reply With Quote
Old 11-26-2010, 08:23 PM   #2
Rewards Points: 6,652
You could try for what it is worth, since tree lights are a parallel/series circuit, but to me, that would be a ugly fix. How old is this tree? If over four years, get a new one, since lights are only good for about five years.
Old 11-26-2010, 08:25 PM   #3
No you can't cut them & wire them together
Usually they skip every other socket
So one wire is "common"...other 2 wires skip & each feeds every other socket
Old 11-26-2010, 10:02 PM   #4
I did it and it worked. Is this a safety issue, or since it worked, it's good.
Old 11-26-2010, 10:03 PM   #5
Only hazard will be burning out all the lights in a short time period
Old 11-27-2010, 11:40 AM   #6
Rewards Points: 2,800
How were the three wires connected within the socket assembly and where did the wires lead out to?
The result of merely wire nutting all three wires together cannot be predicted. One possibility could be a short circuit.
If it worked for you then you were lucky.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Problem with Christmas lights burning out asugrads Electrical 21 12-20-2011 02:28 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 11:53 AM
Use factory fog light switch for aftermarket lights? downunder Automotive Repairs 6 07-10-2010 11:45 AM
Possible Breaker Problem mmcgrath Electrical 12 04-19-2009 09:41 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
