Probably Not, Right? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2010, 10:36 AM   #1
the Musigician
DangerMouse's Avatar
Probably not, right?
If I glued the plastic back together, I don't think the inspector would pass it....
Does anyone know where and how much it might be to replace just this part?
Square-D Load Center.
Thanks!
DM
Old 07-20-2010, 11:11 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 946
Buy the same panel and replace the guts.
Might not work if a much older panel.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 07-20-2010, 11:25 AM   #3
Rewards Points: 202
I wouldn't worry about the inspector in this case. Think of yourself, or the next person to come along, and don't try to repair it; replace it. You may be able to find a local contractor who has a good used one, but not real likely, and rather than waiting for a special order, given the price difference, I agree with simply buying a new panel, and switching it over. Just remember that the torque on those things is marked in inch/pounds, not foot/pounds. :-)
Old 07-20-2010, 11:30 AM   #4
the Musigician
I didn't do it, I got it used and found it this way. I DID just have the idea of calling Habitat for Humanity ReStore and asking them if they have panels. I'm sure they will, so I'll let ya know. But 200-300 for a new panel just don't fit our budget. (with the 3 afcis)
DM
Old 07-20-2010, 11:31 AM   #5
jbfan's Avatar
Rewards Points: 946
an empty panel should cost less than $100.
HD and Lowes sell panels with breakers for $100.
Old 07-20-2010, 12:01 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
That looks like a QO 100A main lug panel. About $50-$60 bucks.
Old 07-20-2010, 12:14 PM   #7
the Musigician
It says it's a 125a, is that OK for my 100a existing system?
DM
Old 07-20-2010, 12:33 PM   #8
Licensed electrician
Rewards Points: 3,654
The 125 rating is the maximum that the panel can be used with. Any lower ampacity is fine.
DangerMouse (07-20-2010)
Old 07-20-2010, 12:46 PM   #9
the Musigician
Thought so, thanks. Po)
DM
Old 07-20-2010, 12:49 PM   #10
Rewards Points: 202
Restore is actually not a bad idea, although, based on my experience, if it's not too far away, you might be better off to just drive there, and look for yourself. The volunteers all mean well, but sometimes I have found them to not be the most knowledgable.
Old 07-20-2010, 12:55 PM   #11
the Musigician
Yeah, but Joe's a friend of mine.... Po)
DM
