Power Supply To Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 09:36 PM   #1
Power supply to Garage
At my cabin, I have a 220 stove receptacle not being used (I have a gas stove) I've built a garage and would like to run a line and hook up a temporary power supply for this winter only. Next year I'll do the proper (and legal) underground connections, wiring, etc. Can I run a cable from the cabin to say, a 30 amp box and split it to a couple 15 amp breakers? Not asking how, just if it's possible before i appraoch an electrician.
bushmoose is offline   Reply With Quote
Old 11-19-2010, 09:58 PM   #2
Rewards Points: 150
Possible? Always.
Legal? Sometimes.
In either case, not exactly as you've worded it, but the concept is right.
I created some peculiar (and, in retrospect, scary) variations of what you propose in my past. It always worked, nobody ever got hurt, but the potential was there. If you're this unsure of what you're doing, DEFINITELY follow the advice of an electrician, who will almost definitely tell you that "plugging in the garage" is a bad idea.
emolatur is offline   Reply With Quote
Old 11-21-2010, 03:51 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 3,620
As emolatur says, almost anyone qualified will tell you that "plugging in the garage" is a bad idea... but it's almost certainly possible to do, and might even be doable relatively safely. However, it's probably no simpler than just wiring it from the panel. You could run a temporary cable overhead to the garage (4-wire UF might be a good choice; you can bury that same cable later), and wire it to the breaker that used to feed the stove receptacle. That avoids the whole problem of dealing with plugs and cords, and the probable issue of 3 versus 4 wire range receptacles.
mpoulton is online now   Reply With Quote
Old 11-21-2010, 09:27 AM   #4
Thanks fella's! As you probably guessed, I'm no electrician. This idea was suggested to me and I thought I'd put out a few 'feelers" and see what sort of feedback I would get. Maybe just a couple of extension cords will work for the winter months, safer and less hassle.
Old 11-21-2010, 10:25 AM   #5
Rewards Points: 308
Thats it. Extension cords. Safest way.
Old 11-21-2010, 07:50 PM   #6
Rewards Points: 150
Yeas as long as it is moved once a year and the garage is not attached to the house. Then it is considered temp if you disconnect once a year roll up the cord and do it again.
ianc435 is offline   Reply With Quote
Old 11-22-2010, 09:11 AM   #7
Rewards Points: 256
Elliot, this is a do it yourself forum.
michaelcherr is offline   Reply With Quote
changing the power supply robut PC Repairs & Upgrades 4 01-08-2011 01:29 PM
No Power in Garage k_c_Ckat Electrical 3 11-04-2010 04:18 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
conducting water supply to detached garage amakarevic Plumbing 12 02-29-2008 10:35 AM
wiring up two lights to one power supply divy Electrical 6 02-11-2008 05:49 AM
