Power To A Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2010, 11:26 AM   #1
power to a sub panel
I recently installed a new 200 amp service in my house. I have a 100 amp panel in excellent shape I would like to install in my shop located about 250' away and have a roll of direct burial #3AWG wire to connect the two. If all this sounds good so far, the plan is to install a 50amp 2 pole breaker(SquareD) in the 200 amp box to power the panel in the shop. What is the best way to make the connection between the 50 amp breaker and the #3 wire ?
BigHill is offline   Reply With Quote
Old 08-03-2010, 11:49 AM   #2
The breaker should list the Max wire size that can be connected
I thought a 50a could take up to #2 wire
Old 08-03-2010, 11:59 AM   #3
Electrician
Proby's Avatar
You can buy the reducer pictured below from just about anywhere, Home Depot has a pair of them in a bag for about $5. While you're there, pick up a couple feet of #8 THHN to serve as pigtails from the breaker to the reducer.
How many wires in your direct burial cable?
You'll need to drive a ground rod at your shop.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-03-2010, 12:04 PM   #4
Licensed electrician
Rewards Points: 3,658
Is your cable 3 or 4 conductor? A 4 wire feeder is required under the 08 Code.
Old 08-03-2010, 12:12 PM   #5
Electrician
Proby's Avatar
I know you need separate neutral and grounds, but could you use a 3-wire to run a single hot out to the separate structure? I never looked into it because I would probably never do it. But in the case of the OP in which he has the wire already, it might be cost effective.
Old 08-03-2010, 12:19 PM   #6
Just call me Andrew
Rewards Points: 1,032
Even if up to code, wouldn't that only give him 120v in the workshop? Good chance his shop will require some 220v tools.
Andrew
secutanudu is offline   Reply With Quote
Old 08-03-2010, 01:27 PM   #7
I guess you could run a 3 wire feed to a outbuilding panel if you only expected 120 volt loads. Half the breaker slots would be unavailable for use. IMO I would not run less than a 4 wire feeder, even if only a small one.
Old 08-03-2010, 01:36 PM   #8
Electrician
Proby's Avatar
I've found sub-panels in houses that were only fed with one leg, they jumped the buses together so the whole panel was hot.
Oddly enough, I couldn't find anything saying this was against code. I believe I asked on Mike Holt's forum and no one else found anything either.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Running power to small barn in VA from home service 350' ribertgropius Electrical 9 06-12-2010 02:18 AM
Power Save Device capt2 Electrical 52 02-24-2010 06:42 PM
Sub Panel SoxFan Electrical 2 12-02-2008 10:16 AM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
