Power From Outlet To Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 09-21-2014, 09:51 AM   #1
Rewards Points: 1,132
Power from outlet to shed
Have an outlet mounted against my house right behind my gate door. My shed is parallel to the outlet right across our walkway . So it's about 4' away. I would like to get power to my shed. I was thinking of running an extension cord for. The outlet ru along the ground to the shed. But one of those orange extension cords would look shi$&y. Any other thoughts on how to get power there? One of those indoor extension cords would be ok because they are brown and the pavers are brownish but it's indoor. Thanks
Mstrlucky74 is offline   Reply With Quote
Old 09-21-2014, 10:27 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
What about direct burial wire or conduit.
Robpo is offline   Reply With Quote
Old 09-21-2014, 10:43 AM   #3
Super Moderator
joed's Avatar
Rewards Points: 31,710
Any type of wire.cable over the top of the ground is dangerous. It is a trip hazard and a could be damaged easily and become a shock hazard.
The cable should be buried or run overhead at the proper height. An extension cord is not an option for either method.
The Following User Says Thank You to joed For This Useful Post:
Jim Port (09-21-2014)
Old 09-21-2014, 12:39 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 816
I would think that someone with 735 posts on this forum would know an extension cord is not a compliant solution.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 09-21-2014, 01:59 PM   #5
Super Moderator
joed's Avatar
Don't know how many of those posts are in electrical, but obviously not since that was the plan.
Old 09-21-2014, 04:15 PM   #6
Rewards Points: 18,808
One of my many pet peeves.
EG: I want to wire my shed, garage, whatever.
I'm only going to need one light and an outlet.
They then under wire it, then want to run an A/C, add outlets, power roof fan, 220 volt power tools, ECT.
Whole lot cheaper and easier in the long run to at least run over sized wiring from a double breaker from the panel and add a small subpanel then to have to do it all over again.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
curtd (09-21-2014), wkearney99 (09-22-2014)
Old 09-21-2014, 06:26 PM   #7
Ok I have about a 2" channel that is dirt.... It runs from my house across the path to the shed I'm gonna run 12/2 UF and bury it in thier. I going to pull power from the receptacle.
Old 09-21-2014, 08:35 PM   #8
Rewards Points: 332
Send a message via Yahoo to curtd
My neighbor just recently installed a electrical wire beneath ground. Had a electrician do it. He went down 18 inches, and ran the electric wire inside a 2 or 2.5" pvc pipe which makes sense for 2 reasons. 1) When transplanting plants we don't even come close in having to dig down 18" 2) One will hit the pvc pipe first instead of the wire Of course, always call before you dig (it's the law) http://www.call811.com/
curtd is offline   Reply With Quote
Old 09-21-2014, 09:15 PM   #9
Super Moderator
joed's Avatar
It is also code. 18" for conduit and 24" for cable only.
Power Outlet that stays off when power fails hachadwick Electrical 9 01-11-2013 10:38 AM
Do I have any more electrical service capacity? (Power for Shed) Magnus357 Electrical 7 10-13-2012 08:52 AM
Running Power to Shed Question mclemenc Electrical 13 01-03-2012 07:25 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 05:38 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
