Power Inverter For Laptop - Electrical - DIY Chatroom Home Improvement Forum
Old 07-08-2010, 11:32 AM   #1
Just call me Andrew
Rewards Points: 1,032
Power Inverter for laptop
Trying to get a power inverter for a friend's laptop. The "official" car charger from dell is here, and 65 Watts:
http://accessories.us.dell.com/sna/p...9&sku=330-0732
Does this mean I have to get a 65 watt inverter, or can I get her a 90 watt inverter, so she can use it for things that my require a bit more power?
Maybe something like this with USB:
http://www.walmart.com/ip/Wagan-Smart-AC-80-Watt-Inverter-with-USB/14521523
Any suggestions?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 07-08-2010, 11:58 AM   #2
gmhammes's Avatar
You can get as big as you want but it needs to be atleast 65 watt.
gmhammes is offline   Reply With Quote
Old 07-08-2010, 12:06 PM   #3
Just call me Andrew
Cool - just what I was hoping. Thanks.
Andrew
Old 07-08-2010, 12:09 PM   #4
I=E/R
a7ecorsair's Avatar
What, exactly, are you looking for?
The first link is for an AC adapter. This plugs into a wall outlet and provide DC power to the laptop.
The second link is an DC inverter. It converts 12DC to 120 VAC. You would then need an AC Adapter to provide power to the laptop.
a7ecorsair is offline   Reply With Quote
Old 07-08-2010, 12:13 PM   #5
Just call me Andrew
Yeah, the inverter is fine. She already has the AC adapter that came with her laptop.
I am thinking the inverter is better, since it'll give her a place to plug other things in as well. Some even have a USB port on them to charge iPods, etc.
I linked the wrong adapter in the first link, I meant to link the car charger.
Do you think getting some no-name brand inverter w/ USB for $12 is a bad idea, or are they one and the same?
Andrew
Old 07-08-2010, 12:24 PM   #6
I=E/R
a7ecorsair's Avatar
You can get an inverter with 90 watts available for $12?
It probably doesn't matter that it is no-name, they're all made in china.
Old 07-08-2010, 12:33 PM   #7
Just call me Andrew
How about this one...75w:
http://cgi.ebay.com/75W-Power-Invert...item563ba83f49
Andrew
Old 07-08-2010, 12:43 PM   #8
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 528
75W won't power much, so if you want something you can use for other uses, I'd get a 500w or so. They are fairly cheap, and very handy to have.
Old 07-08-2010, 12:46 PM   #9
gmhammes's Avatar
Beware though when get into the higher wattage converters you will most like be wiring them to your vehicles battery as opposed to plugging them into your cigarette lighter outlet. Those outlets can usually only handle 10-15amps of draw.
Old 07-08-2010, 12:48 PM   #10
Just call me Andrew
As long as it works for her laptop and iPod at the same time....that's all I want. I'll probably just go with 100w or so.
Andrew
Old 07-08-2010, 12:53 PM   #11
gmhammes's Avatar
you could plug the ipod into the laptop
Old 07-08-2010, 05:05 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
I have a 100 watt inverter that plugs into the lighter and I use it to charge my batteries.
Black and Decker, and cost about $20 at HD.
No usb port.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 07-10-2010, 02:43 AM   #13
Rewards Points: 1,016
I have had very good experiences with inverters from Tripplite - I have used many to include both their smaller portable units that plug in, to the larger permanent hard-wired units. Quality products, good value, and a solid very experienced company.
The model 150 would work for you - http://www.tripplite.com/en/products...xtModelID=2553
Emergency power backup via power inverter upabove Electrical 14 06-08-2010 11:18 PM
Add more power to the house? (kinda long) tmtrebor Electrical 5 04-30-2010 03:19 PM
Power Inverter Livewire78 Electrical 2 02-24-2010 08:32 AM
Can I give 12V DC to power inverter through PC Power supply? inverter General DIY Discussions 3 07-06-2009 09:38 AM
Power inverter AndrewL Electrical 6 03-02-2008 01:43 PM
