Power Failure - Electrical - DIY Chatroom Home Improvement Forum
Old 11-07-2019, 02:16 PM   #1
Rewards Points: 2
Power Failure
In kitchen only getting a quick power failure to microwave oven and range oven (not on same outlet) 2nd time in a week and then it's OK again. I checked breakers and they look good. Should I start trouble shooting at the outlets or could the refrigerator which is on the same outlet as the microwave be part of the problem? This old lady needs advice and thanks experts very much.
doc wilson
docwilson is offline   Reply With Quote
Old 11-07-2019, 02:34 PM   #2
retired framer
Rewards Points: 15,550
Re: Power Failure
Are you sure the fridge and microwave are on the same breaker or are they on 2 breakers that go off together or one breaker that is wider than the rest.
Range oven, is lie a full sized stove that plugs into a 240 outlet?
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 11-07-2019, 05:37 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 13,394
Re: Power Failure
Welcome to the forums. Post over in the electrical section as well.
Old 11-07-2019, 08:08 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 31,976
Re: Power Failure
Moved to electrical.
Old 11-07-2019, 08:31 PM   #5
tom_poconos's Avatar
Rewards Points: 508
Re: Power Failure
What size is the breaker? It will have a number on it like 15 or 20. It's likely that even though the appliances are not all on the same outlet they are still on the same circuit.
The fridge draws a bit of power, but when you turn on the microwave and/or the range, you're drawing more than 1800 watts, which is what a 15A circuit can handle before tripping.
On the one ton temple bell
a moon-moth, folded into sleep
tom_poconos is offline   Reply With Quote
Old 11-07-2019, 11:07 PM   #6
dmxtothemax's Avatar
Rewards Points: 7,854
Re: Power Failure
Fridge, microwave and oven ?
You have far too much load on this circuit.
No wonder it's blowing.
Just because you have gotten away with it in the past,
Doesn't mean it's ok
Most kitchens now have dedicated circuits for just the microwave.
And often another dedicated for the fridge,
which saves nuisance blows spoilling food.
Easiest option is run another circuit to your microwave.
dmxtothemax is offline   Reply With Quote
Old 11-10-2019, 04:26 PM   #7
Rewards Points: 1,482
Re: Power Failure
It can be a shared breaker or it can be arcing inside one of the outlets and the latter is a fire hazard. If I were you I would pay an electrician to check out the box and the breaker.
On a separate note the older panels do not have arc-fault sensing breakers and so arcing in a box is more of a concern. On the other hand the arc fault breakers are more prone to "nuisance" tripping.
Calson is offline   Reply With Quote
Tags
appliances , electrical , power failure
