Power Dimms Down For A Split Second... - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 06:43 PM   #1
transmitterrecieverpntgun
Power dimms down for a split second...
I live in a pieced together old house that needs ALOT of tlc and has ALOT of projects done to it in the last 5 years. I have public power and a 200 amp box. The wiring is suddenly giving me fits. About a year ago, the lights started "flickering" for a split second every now and than......It has progressed slowely into a bigger problem. when the dryer is running (220) the lights flicker and dim down repeatedly. This is the same for running a heater, blow dryer or heat device. NO the breakers are not overloaded. It now does it when nothing is on accept a few lights and now started doing it when the well pump kicks on. im at a loss, it will sometimes go all day with not one flicker than the next day every little thing like the fridge kicking on makes them flicker untill it kicks off....ANY IDEAS....ANYONE? No electrician will look at it for anything lass than $250.00 I am in remote Alaska...kinda sorta...not realy...untill people quote theyre prices....than suddenly were WAY out there...
Edit: I should mention that a few years ago I had to shut off the power at the meter because I was working in the crawlspace on a waterline and it was giving me the heebeegeebeees crawling around down there...I bumped a low hanging wire and nothing happened...but it still freaked me out... When I went to turn back on the power, The dryer and well pump didnt work. During the trouble shooting process, I turned on and off the power out at the meter a few times and it suddenly started working again...I chalked it up to devine entervention and have not ever had problem with the well or dryer since.....creepy
utilitylocator is offline   Reply With Quote
Old 11-29-2010, 06:47 PM   #2
Electrical Contractor
kbsparky's Avatar
Did you call the power company? Sounds like a bad/loose connection on their end.
With the temperature extremes of Alaska, it is quite possible for a connection to go bad after awhile. The power company should be asked to check all their connections, from the transformer to the meter box. Once they have confirmed their end is on the up and up, THEN call in an electrician if the problem still exists.
-KB
Old 11-29-2010, 10:57 PM   #3
if not on the power companies end, check for a loose neutral coming into your panel. i had a very similar issue to the one you describe, and that was my problem. (actually, it wasn't loose, it was corroded away and non existent...)
1910NE is offline   Reply With Quote
Power tool Junkie Question UpComingBuilder Tools 3 10-05-2009 09:24 AM
No Power at Electronic Air Cleaner Junction Box edge10 HVAC 1 09-28-2009 07:26 PM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 08:17 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
