Potlights Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-04-2010, 10:51 PM   #1
potlights wiring
I have 4 potlights for the basement, would like to operate them with 1 switch only, my question is about the wiring, how to connect them together without blowing up the"hood" thanks
wilson luna is offline   Reply With Quote
Old 02-04-2010, 10:59 PM   #2
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Blowing up the Hood !? Don't get it. But you just wire them in series from one to the next. Use 14/2
ryanh is offline   Reply With Quote
Old 02-04-2010, 11:14 PM   #3
potlights wiring
Thanks Ryanh for your quick response, I have very little knowledge about electrical stuff, could you elaborate about the wire connections. I meant I don't want to blow up the neighbourhood.
Old 02-04-2010, 11:15 PM   #4
E-lec-tri-city
Rewards Points: 150
Send a message via ICQ to brons2 Send a message via AIM to brons2 Send a message via MSN to brons2 Send a message via Yahoo to brons2
white to white, black to black, ground to ground pretty much. when you get to the last light just connect that light only. Use wire nuts if your pots don't include connectors. My pots had Romex quick-connectors in the box so I didn't need anything other than pliers and a wire stripper. I'm adding 24(!!) pots in my house as part of my current project. I hate how dark it is in my place and I am making sure that it will never be a problem again.
brons2 is offline   Reply With Quote
Old 02-05-2010, 10:56 AM   #5
ryanh's Avatar
Rewards Points: 154
Ya most pot lights now have the quick connectors . just match them up
Old 02-05-2010, 11:02 AM   #6
pull a single run of 14-2 from swich to first light then from that light to next etc. connect as stated above
The older I get the better I was
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
