Potlight Turning Off - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2010, 09:18 PM   #1
Rewards Points: 152
potlight turning off
I installed some potlights/recessed lights in my house. I installed the potlight with the insulated metal box in the attic. After having the potlight on for a couple of minutes, one of the potlights turn off.
Is it because their's too much insulation around the insulated box?
humberguy is offline   Reply With Quote
Old 06-01-2010, 09:35 PM   #2
Electrical Contractor
kbsparky's Avatar
Are those IC rated (direct contact with insulation)?
Using too large a bulb can cause the symptoms you described.
-KB
Old 06-01-2010, 09:38 PM   #3
Rewards Points: 152
Their non IC, the bulbs came in the kit(6 lights with 6 bulbs). I bought the insulated box made for those potlights.
Old 06-02-2010, 04:50 PM   #4
Master Electrician
i've seen the cheaper lights(gu10's in particular) that come the sixpack like that for $50 bucks or so flicker alot. The lights aren't built to dissapate the heat that well and the little hologens throw alot of heat. The temperature switches will kick in alot especially in an attic when it's warm outside.
andrew79 is offline   Reply With Quote
Old 06-02-2010, 04:53 PM   #5
What type/wattage of bulbs are you using ?
Might try using CFL's to cut down on heat
Old 06-02-2010, 06:54 PM   #6
Rewards Points: 152
thanks for the responses, it turns out the brand new GU10 bulb already blew, so i put a new bulb in their and it works.
Im happy it wasnt a overheating problem. Buying cheap bulbs gives cheap results.
Old 06-02-2010, 06:55 PM   #7
Rewards Points: 152
What are CFL's? so i can know for future reference.
Old 06-02-2010, 07:26 PM   #8
CFL = Compact Flourescent Light (usually seen as the twisty curly bulbs)
Only uses ~11w for a GU10 - Halogen uses 50w I think ?
So you save on electric use & less heat
Old 06-02-2010, 07:33 PM   #9
Rewards Points: 152
and that bulb is actually the size of a regular GU10 and would fit in the socket? I never seen those, would be nice to install those to save energy
Does homedepot sell that? I dont think ive ever seen that at home depot.
Old 06-03-2010, 03:10 PM   #10
Rewards Points: 216
[IMG]file:///C:/DOCUME%7E1/NewAdmin/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Home Depot here in Canada also sells a Phillips LED version 7watts - but it's about $30.
orange is offline   Reply With Quote
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
shower potlight mounting humberguy Electrical 1 01-22-2010 05:54 AM
Pluming Hot Water Turning Cold - Help! kissiffer4 Off Topic 1 01-14-2010 05:00 PM
HELP - Lost water pressure to shower after turning off water to house jpw28 Plumbing 8 02-20-2008 08:07 PM
turning off water Jack Hass Plumbing 1 02-03-2007 09:00 PM
