DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   potlight turning off (https://www.diychatroom.com/f18/potlight-turning-off-72611/)
humberguy 06-01-2010 10:18 PM
I installed some potlights/recessed lights in my house. I installed the potlight with the insulated metal box in the attic. After having the potlight on for a couple of minutes, one of the potlights turn off.
Is it because their's too much insulation around the insulated box?
kbsparky 06-01-2010 10:35 PM
Are those IC rated (direct contact with insulation)?
Using too large a bulb can cause the symptoms you described.
humberguy 06-01-2010 10:38 PM
Their non IC, the bulbs came in the kit(6 lights with 6 bulbs). I bought the insulated box made for those potlights.
andrew79 06-02-2010 05:50 PM
i've seen the cheaper lights(gu10's in particular) that come the sixpack like that for $50 bucks or so flicker alot. The lights aren't built to dissapate the heat that well and the little hologens throw alot of heat. The temperature switches will kick in alot especially in an attic when it's warm outside.
Scuba_Dave 06-02-2010 05:53 PM
What type/wattage of bulbs are you using ?
Might try using CFL's to cut down on heat
humberguy 06-02-2010 07:54 PM
thanks for the responses, it turns out the brand new GU10 bulb already blew, so i put a new bulb in their and it works.
Im happy it wasnt a overheating problem. Buying cheap bulbs gives cheap results.:huh:
humberguy 06-02-2010 07:55 PM
What are CFL's? so i can know for future reference.
Scuba_Dave 06-02-2010 08:26 PM
CFL = Compact Flourescent Light (usually seen as the twisty curly bulbs)
Only uses ~11w for a GU10 - Halogen uses 50w I think ?
So you save on electric use & less heat
http://ecx.images-amazon.com/images/...500_AA300_.jpg
humberguy 06-02-2010 08:33 PM
and that bulb is actually the size of a regular GU10 and would fit in the socket? I never seen those, would be nice to install those to save energy :thumbup:
Does homedepot sell that? I dont think ive ever seen that at home depot.
orange 06-03-2010 04:10 PM
1 Attachment(s)
[IMG]file:///C:/DOCUME%7E1/NewAdmin/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]
Home Depot here in Canada also sells a Phillips LED version 7watts - but it's about $30.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
