Pool Shock - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2010, 10:54 AM   #1
pool shock
I am getting shock on metal handrail when getting out of in-ground pool. Any suggestions how to trouble shoot? Thanks, Mark
Mark Howard is offline   Reply With Quote
Old 06-07-2010, 11:49 AM   #2
Licensed electrician
Rewards Points: 3,662
The first thing I would have checked is that the pool is properly bonded. You also need to find out what is causing the shock. I would suggest turning of the breaker for the pool until this is settled.
Old 06-07-2010, 01:07 PM   #3
Sparkaholic
Rewards Points: 150
Send a message via Yahoo to sparks1up
If you are getting shocked by the handrail the pool system is not properly bonded and you have an electrical fault somewhere. The fault may or may not be related to the pool system wiring. It could be coming from any circuit that passes near the pool and comes in contact with the steel in the concrete or any metallic part that makes up the pool deck or structure.
Unless you are knowledgeable in electrical troubleshooting and bonding I have to recommend that you call a licensed electrician!
Answers based on the mood I am in when you ask!
sparks1up is offline   Reply With Quote
Old 06-07-2010, 10:28 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Turn off the breaker to all the pool system and check the bonding first then you will need to test which circuit it will affect and also the cirictal item that you should have functing RCD { GFCI } this is very important part if this RCD is not working you need to replace it and test it.
Anything more than that I really seriously suggest that you get a electrician to come out and they will check out the system very carefull.
Merci,Marc
Pool parts...what is this for? tripflex Plumbing 5 02-17-2012 06:32 AM
pool "current" pipefitter Electrical 60 09-20-2011 07:50 AM
Running power to pool equipment???? kj 47 Electrical 10 03-27-2010 05:02 PM
First thing to do to pool? tripflex General DIY Discussions 21 09-29-2009 11:55 AM
voltage potential around in-ground pool logi98 Electrical 20 07-05-2009 08:08 PM
