Plug Problems In The House. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2009, 07:40 PM   #1
plug problems in the house.
Hi,
i just moved into my new house.
i had an electrician come by and switch the plugs for me before he changed them i tested each one witha pen tester to see if it works and all of them have been working.
he changed the plugs but 2 are nto working idk why and i cant get a hold of him anymore and i got no more moeny to spend wondering if you guys can help me
heres the problem
2 plugs in the kitchen are under double pole 15 amp breakers they both have ground which is ont he ground screw and have 1 hot wire whihc si on the blakc screw atm and 1 red wire whihc is under the black screw and a neutral whihc is under the white screw.
panel says they are "split"
when you turn on the breakers it keeps tripping.
whats the problem?
Ivancar1 is offline   Reply With Quote
Old 07-05-2009, 07:42 PM   #2
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Unlicensed electrician?
Illegal immigrant worked there?
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 07-05-2009, 07:43 PM   #3
I ahve no clue i found him under the "Yellow Pages" i already called the goverment to report him but they still ahve not done anyhting
Old 07-05-2009, 07:48 PM   #4
Magnettica's Avatar
Rewards Points: 150
Well if he was in the Yellow Pages he was likely licensed unless you're in a state that doesn't require licensing.
The problem you describe tells me you have what's called a multiwire branch circuit, which is fine, but the electrician apparently forgot to remove the tab that bridges the circuit on the receptacle.
The black is one circuit, the red is another circuit, and they share a common neutral.
What it sounds like you need to do is break the tab that bridges the black and red. BUT DON'T DO THIS ON THE WHITE NEUTRAL SIDE.
Old 07-05-2009, 07:48 PM   #5
Magnettica's Avatar
Rewards Points: 150
Oh... what a shock!
Old 07-05-2009, 07:50 PM   #6
Ok can u explain to me how to do this step by step please?
Right now i have a plug sticking out actually 2 plugs that are not working
they both have
a ground on them
1 neutral on white screw
1 hot on black screw
1 red on black screw
what would i need to do?
Old 07-05-2009, 07:58 PM   #7
Magnettica's Avatar
Rewards Points: 150
First, make sure the circuit breaker is off which im sure it is since you're here asking for help.
Next, undo the black wire from the terminal, then do the same for the red.
Next, take a pair a side cutters and cut out the copper tab that "bridges" the red and black wires on the receptacle together.
Put the wires back as they were, re-energize the circuit.
I'll be back in 60 minutes. Ice Road Truckers is starting.
Old 07-05-2009, 08:00 PM   #8
ok the copper tab is found on the plug right?
Old 07-05-2009, 08:13 PM   #9
Licensed electrician
Rewards Points: 3,740
I believe from the description of the problems that the OP is in Canada.
Old 07-05-2009, 08:18 PM   #10
Super Moderator
joed's Avatar
Rewards Points: 30,876
The tab is on the hot (gold) side of the receptacle and joins the two gold screws together. In this case with a split receptacle the tab needs to be removed ONLY ON THE GOLD screw side.
An electrician or would have known to cut the tab.
Old 07-05-2009, 08:42 PM   #11
Magnettica's Avatar
Rewards Points: 150
200 Amp service really needed for a 830 sq ft house? overkill? alexz Electrical 7 11-16-2009 05:54 PM
Unpolarised US Type 2 Plug to UK Plug. razorcut Electrical 19 05-18-2009 09:49 AM
Concrete roof on house... problems!! flipjarg Roofing/Siding 6 01-24-2009 10:06 PM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
Complete AC installation in Old Capitol Hill Row House jacko10 HVAC 0 09-18-2007 05:42 PM
