Plug-in Model Of Programmable Timer Switch ? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2009, 10:06 PM   #1
Plug-in model of programmable timer switch ?
Is there such a thing like a plug-in model of these timer switch, (e.g., the Leviton one below) : that I can easily just plug in lamps or other small devices to control them instead of having to re-wire devices to connect to the switch ?
http://www.amazon.com/Leviton-6124H-...m_cr_pr_sims_t
timcsi is offline   Reply With Quote
Old 11-04-2009, 10:10 PM   #2
" Euro " electrician
frenchelectrican's Avatar
C'est simple here the wall plug in timer it will function simair and it will work for your table luminaire.
http://www.amazon.com/Intermatic-TN1...7394144&sr=1-9
Merci,Marc
Old 11-05-2009, 07:00 AM   #3
DIYguy2000's Avatar
Rewards Points: 93
We bought one from Canadian Tire (i think) that has little buttons you press down in half hour increments for a full 24 hours. That way you're not limited to 2 on/off cycles per day, you can have it turn on/off whenever you want. They're out there.
DIYguy2000 is offline   Reply With Quote
Old 11-05-2009, 07:09 AM   #4
I see, can I get these from HD or Lowes instead of online ?
Old 11-05-2009, 07:07 PM   #5
Oh yeah ! they are just about everywhere you can find them in big box store or even in wallyworld store they will have it in there.
Merci.
Marc
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 09:34 PM
Installing timer switch, no ground wire in switch box diydan Electrical 2 05-25-2009 07:51 PM
4 way switch wiring ponch37300 Electrical 9 02-16-2009 09:58 AM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 02:53 PM
