Please Help Me Trouble Shoot My 3 Way Switch - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-29-2014, 10:35 AM   #16
Rob
Robpo's Avatar
Rewards Points: 826
Do you have a tester and know how to use it?
Robpo is offline   Reply With Quote
Old 06-29-2014, 10:42 AM   #17
Don't WANNA do it myself
mnp13's Avatar
Rewards Points: 512
Yes and yes.
*edit - yes I have one. Yes I know how to use it to test outlets, live wires and such. I do not know how to trouble shoot this problem with it.
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 06-29-2014, 10:44 AM   #18
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by mnp13 View Post
Yes and yes.
So does the light come on with the switches in any position? Do you have power? what's the scoop?
Old 06-29-2014, 10:49 AM   #19
Rob
Robpo's Avatar
Rewards Points: 826
He says when both switches are down the light is on.
The Following User Says Thank You to Robpo For This Useful Post:
mnp13 (06-29-2014)
Old 06-29-2014, 11:04 AM   #20
mnp13's Avatar
Rewards Points: 512
My switches look just like this.
Michelle
Old 06-29-2014, 11:05 AM   #21
E2 Electrician
Hahaha... totally missed that part, with that said, just reverse one of the travelers, but in all honestly, its working perfectly.... to ease your pain, just flip one of the three ways 180 degrees, problem solved.
Old 06-29-2014, 11:07 AM   #22
mnp13's Avatar
Rewards Points: 512
LOL
If only!
Michelle
Old 06-29-2014, 11:07 AM   #23
mnp13's Avatar
Rewards Points: 512
Swap the traveler with the common?
Michelle
Old 06-29-2014, 11:07 AM   #24
E2 Electrician
LOL
If only!
I'm dead serious....
Old 06-29-2014, 11:09 AM   #25
E2 Electrician
Do your switches work in any other position than both being in the down position? If not, you have a bad three way switch.
I was totally confused on your issue... I had a rough night last night.
Old 06-29-2014, 11:10 AM   #26
mnp13's Avatar
Rewards Points: 512
Both down is the only way they work.
Michelle
Old 06-29-2014, 11:22 AM   #27
mnp13's Avatar
Rewards Points: 512
And how do I figure out if it's a bad three way switch? These things aren't exactly free...
Michelle
Old 06-29-2014, 12:15 PM   #28
Rob
Robpo's Avatar
Rewards Points: 826
Flip both switches up and the switch where neither traveler is hot to ground is the switch that is bad. If neither switch is hot I will have to look at your pic again.
Old 06-29-2014, 12:28 PM   #29
Rewards Points: 3,396
you really should have a tester.
you can eliminate the switches and temp wire power down to a traveler, back on the black and up to the light.
then try the other traveler the same way. If that makes sense?
ritelec is offline   Reply With Quote
Old 06-29-2014, 12:49 PM   #30
mnp13's Avatar
Rewards Points: 512
I do have a tester. I'll check it in a few. Taking a break right now.
Michelle
3 speed ceiling fan switch trouble Ladmo1 New Member Introductions 0 07-05-2012 03:26 PM
3-way Switch to always hot receptacle - wiring trouble Waterfroggy Electrical 7 05-07-2012 10:00 PM
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 11:37 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
