Plastic Weather Proof FSB Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2015, 10:39 PM   #1
Rewards Points: 2,430
Plastic weather proof FSB box
I was doing some wiring outside and used a plastic FSB box.
I had to run conductors from two places to this box then from there to a third location...this over several days and it rained every day, so I had to open and close the box cover multiple times.
By the time I am all done, I noticed the four metal screws that go onto the weatherproof cover have already chew through the four holes on the box one too many times so the screws spin and no longer very tight.
I can't change the box now that all the conductors are in and the boxes and conduits are glued.
I could try using larger diameter screws, but they may break the plastic screw holes on the box.
Suggestions?
miamicuse is online now   Reply With Quote
Old 08-16-2015, 08:48 AM   #2
Master Electrician
Rewards Points: 5,082
Fill the screw holes with epoxy, let the epoxy set up, drill be holes, insert screws.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
rjniles (08-16-2015)
Old 08-16-2015, 09:06 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 710
Or the old trick, glue in a few tooth picks.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 08-16-2015, 11:38 AM   #4
Rewards Points: 3,396
Or Teflon tapa around screw.
Or galvanized sheet metal / sheet rock screw
Or get a blank cvr and drill and use the other four holes.
ritelec is offline   Reply With Quote
Old 08-19-2015, 04:18 PM   #5
Rewards Points: 299
Had this happen to me as well. Drilled out the holes and used #8 sheet metal screws instead. The threads are coarse enough you should not have this problem.
Syberia is offline   Reply With Quote
foundation concrete and cold weather taoman1 Concrete, Stone & Masonry 11 12-12-2013 04:36 PM
Installing drywall in cold weather, and sometimes part of wall only (disaster relief) Deck Drywall & Plaster 7 01-19-2013 01:37 AM
Wooden Windows or Plastic? Richuw Windows and Doors 15 04-05-2012 10:16 AM
Can you snake plastic pipes? rosemonster Plumbing 10 01-17-2011 07:09 AM
What size plastic sheeting to use? Joe D Painting 2 01-11-2011 11:03 AM
