Plastic Box Extender With Metal Box - Electrical - DIY Chatroom Home Improvement Forum
Old 07-20-2013, 11:10 AM   #1
Plastic box extender with metal box
I've got a box for an outlet that's pretty deep in the wall. It's too deep for a metal extender. I considered telescoping multiple metal extenders together, but that seems like a kluge
Is it acceptable to use a plastic extender on a metal box? The plastic extender would not slide insider the box but instead would but up against the box because the plastic extender is the same dimensions as the original metal box. Is does butt nice and flush up to the box and would provide sufficient depth to bring it outlet flush to the wall. A few questions:
1) Is a plastic extender on a metal box ok?
2) Is it ok to be butted up against the box instead of telescoped inside of it?
3) If yes to both of those, final question: wire should be grounded to original box - correct?
Thanks!
cplbs is offline   Reply With Quote
Old 07-20-2013, 11:17 AM   #2
Licensed electrician
Rewards Points: 3,608
The box and receptacle both would need to be connected to the ground wire.
Installed flush to the metal box should be fine as long as the grounding is intact.
cplbs (07-20-2013)
Old 07-20-2013, 11:25 AM   #3
Thanks Jim, so does that mean the plastic extender on the metal box is ok too?
Old 07-20-2013, 11:47 AM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
As long as the receptacle and metal box are grounded the plastic extender is fine.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
cplbs (07-20-2013)
Old 07-20-2013, 12:12 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I'd use an Arlington BE-1. Those will slip inside the box.
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (07-21-2013)
Voltage in the Shower Deacon98 Electrical 32 01-19-2012 04:14 PM
Redgard vs 6mil Plastic Sheeting for tiling amodoko Remodeling 0 01-17-2012 11:57 PM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
plastic or metal boxes Clutchcargo Electrical 26 10-27-2010 08:07 AM
Flange Help Needed tajones44 Plumbing 2 07-11-2005 04:42 PM
