PC Keeps Tripping Breaker - LOSING MY MIND! - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-18-2016, 02:50 PM   #16
Rewards Points: 28
Re: PC Keeps Tripping Breaker - LOSING MY MIND!
Originally Posted by Pharon View Post
No. Double conversion UPS's are typically more expensive than line interactive or standby UPS's. But there's a good reason for that.
Okay, that's fine. I'll see if I can squeeze a few bux out of the hookers n' blow fund. Thanks.
tenebrousabyss is offline   Reply With Quote
Old 03-18-2016, 02:51 PM   #17
Rewards Points: 6,652
Not really. I have a Tripplite and a APC that I got brand new for under $200. I use the Tripplite for my A/V equipment and the APC for my network equipment. I have had no issues with either one handling problems.
Old 03-18-2016, 02:52 PM   #18
Originally Posted by jreagan View Post
Maybe a UPC like CyberPower or others? That should give you some isolation and conditioning.
I use one of these: https://www.cyberpowersystems.com/pr...p/cp1500pfclcd
I would not touch Cyber Power crap if my life depended on it. APC & Tripplite is the best to go with.
Old 03-18-2016, 02:59 PM   #19
Rewards Points: 422
What models do you have?
Pharon is offline   Reply With Quote
Old 03-18-2016, 03:52 PM   #20
Rewards Points: 62
Yeah, a good UPS should fix the problem. Or have a brand new dedicated receptacle on a standard 15A breaker installed. Or on the more grey area side, just swap the breaker out for a standard 15A
psgama is offline   Reply With Quote
Old 03-18-2016, 05:31 PM   #21
Rewards Points: 1,832
Id call the landlord and explain the issue before shelling out my money because the manufactures first shelled out cash at the CMP meetings.
Jump-start is offline   Reply With Quote
Old 03-18-2016, 06:33 PM   #22
Rewards Points: 299
Originally Posted by Jim Port View Post
How do you know the circuit is not overloaded? What is the amp draw on the circuit?
If it's a 15 amp circuit it could just be a simple overload. I'm sure you know this but a computer under heavy load (you mention this happens when you start up a game or do other intensive tasks) will consume several hundred watts more than a computer at idle.
Syberia is offline   Reply With Quote
Old 03-18-2016, 07:04 PM   #23
It could be, but AFCIs are also current sensitive as well. Series arc fault analysis starts at around 5 amps and current waveform can change as equipment is put under load. Switch mode power supplies are notorious for high frequency ripple that resembles lab created dangerous arcing.
Old 03-18-2016, 11:18 PM   #24
Rewards Points: 28
Just tested with a kill-a-watt meter. Under full load, 2.65 Amps & 315 Watts.
No way it's tripping a 15A breaker.
Old 03-18-2016, 11:19 PM   #25
Rewards Points: 28
My PC draws far less than 5 amps.
Old 03-18-2016, 11:19 PM   #26
Rewards Points: 28
The landlord refuses to do anything about it because "everything else works fine for everyone else, so it's your problem."
Old 03-19-2016, 12:31 AM   #27
Rewards Points: 62
Actually, I just thought of one more option for you that may actually work,
Grab an extension cord and coil it up in nice round tight coils. Plug your computer power bar into that. The coil will act as line inductance and should cut back some of the harmonics created by your computers switching power supply.
If it works you can thank me for saving your sanity. :p
Old 03-19-2016, 12:39 AM   #28
Rewards Points: 28
That's really interesting. I will give that a try and report back.
Old 03-19-2016, 12:45 AM   #29
Id imagine, but lights and other loads on the same circuit add to that. The AFCI is only interested in a current threshold plus a particular high frequency current ripple. Given the right combination of loads the AFCI will be fooled into seeing a dangerous arc fault.
Sounds like its his way of saying "I dont want to spend any money on my property to solve a potential problem so Id rather you because in the end its more profit for me" For all we know there could actually be a real fault in the circuit that requires attention from a professional.
Unfortunately landlords are known to brush off responsibility. We've had landlords on here where an open neutral existed with smoking electronics trying to find any excuse not to send out an electrician despite their own rental property being an immediate fire risk. I had a landlord years back who refused to fix a leaking hot water heater because "it worked fine before" "dont worry about it then" only to have him come take it out of my security deposit along with the water damage it did when it burst 3 months latter. Come housing court the judge ruled in my favor because he had neglected to send out a repair man when it first started leaking. Reality is your landlord has a duty to send out an electrician or at minimum a maintenance guy to check things out. A breaker is tripping. You assume its your PC as a lay person in electricity. (no offense ) You admit to do nothing wrong or intentional. Thats enough to signal something needs to be repaired or checked out.
Id fight to have the landlord take responsibility because its not fair that you as a hard working person (who did nothing wrong) having to spend money on a double whammy; something that might not fix the problem to begin with while being entirely in the hands of what the property owner is obligated to do. And the fact AFCIs have a long history of nuisance tripping with many professionals holding the opinion they should not have been mandated in the R&D stage.
Old 03-19-2016, 12:53 AM   #30
Semi-Pro Electro-Geek
Rewards Points: 3,652
That actually does not form an inductor. Since both conductors are travelling parallel to each other in the cable, there is no net current flow through the cable and therefore no net current flow through your coil of cord, and no magnetic field. You would need to make a coil of ONE single wire, and insert it in series with the load in order to add inductance. Would take an awfully big coil of wire to produce enough inductance to affect a 60Hz circuit noticeably.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
gregzoll (03-19-2016)
Heat Pump Help! Swapped Contactor, now tripping breaker!!! trifecta50 HVAC 74 02-13-2015 10:00 AM
AFCI breaker tripping in laundry room esahlin Electrical 11 11-27-2014 08:40 AM
Tripping breaker drjay9051 Electrical 5 09-08-2012 03:17 PM
One breaker tripping another armisjam Electrical 12 03-09-2012 09:43 PM
Tripping Wrong Breaker [email protected] Electrical 15 03-28-2008 02:47 PM
