Partial Circuit Outage - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-14-2010, 06:22 PM   #16
Thumbs up
Originally Posted by cantwin1 View Post
OK...got it! While at depot buying a tester wife calls and says the washer / dryer aren't on either. Now I know...since I put the sheetrock on those walls that they are on a different / newer circuit than the old wiring. Therefore the problem has to be closer to the sub-panel than I had thought. Get home with a non-contact tester and go straight to the sub-panel..sure enough...had lost one leg. Go outside to the main panel, pull the breaker, lots of corrosion on the contact. Guess with all the rain we've been getting here water had leaked down and messed it up. Cleaned the best I could with a screwdriver put the breaker back on and everything is back to normal. Moral of the story here...check the easy things first. Thanks for the help guys!
I'm glad to hear your problem is solved (thankfully). I was going to jump in with my Two cents. Just for general knowledge. Some junction boxes, especially in older house wiring, are behind ceiling lights. Older wiring methods were different than those used today. For example, lighting circuits were not run from the bottom up through the switch box and on to the light. Rather, the ceiling box was like a central station where the receptacles and the switch were run from there. And on to the next room, where the same scenario played out from the ceiling box. In all that jumble of wire, there could be a break in one wire or a loose connection. Thankfully, the wiring methods have changed due to code restrictions on "Box Fill", among other things.!
spark plug is offline   Reply With Quote
The Following User Says Thank You to spark plug For This Useful Post:
RST (03-20-2010)
Old 03-15-2010, 06:59 PM   #17
Thanks again guys! Can't believe all the traffic I now see on these forums...wow...appreciate the responses to my issue. And thanks to those that so freely provide help in a forum such as this to everyone else!! I'll try and lend a hand in a few of the areas that I do have experience with.
cantwin1 is offline   Reply With Quote
Old 03-15-2010, 07:10 PM   #18
Electrical Contractor
jbfan's Avatar
Rewards Points: 986
Hey, that's what we get paid to do!
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 03-20-2010, 10:45 PM   #19
If it were my house i would be concerned about the corrosion on the main breaker in your disconnect and how the water was getting in there. Corrosion like that is a good receipe for heat and fire. Might want to consider sealing things up and replacing the breaker. Just my two cents.
two-fer is offline   Reply With Quote
Old 03-21-2010, 12:08 AM   #20
Thumbs up
As you can see. (Almost) Every topic is being discussed here. I once thought that there was an exception. Two topics were not discussed on this DIY forum. Law and Medicine. Turns out that they segway in to the discussion, too.!
Old 03-21-2010, 08:01 AM   #21
get your fridge off ext cord
The older I get the better I was
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
