Panel Upgrade - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-16-2014, 08:17 AM   #16
Licensed electrician
Rewards Points: 3,766
If the service cable is protected at the proper ampacity there is no issue with having a larger panel.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
ben's plumbing (02-16-2014), Stubbie (02-16-2014)
Old 02-16-2014, 12:22 PM   #17
Rewards Points: 582
hey guys ...1 st not only Iam I a registered plumber....Iam also a registered electrician,along with being a registered contractor....my purpose was to get some imput about how others feel about finding code violations ....this panel has 100 amp service with 150 amp main breaker and panel.....that is wrong and would never pass an inspection.... for you smart [email protected]#ss yes there are many good companies here in pa that carry more than one certification, so if you don't have anything constructive to add to post for the benefit of others take a long walk off a short pier..ben sr
Old 02-16-2014, 12:36 PM   #18
Lord of Slums
Rewards Points: 1,974
I am a landlord. I know how to open up a can of hack. If something is illegal in an area I will not touch it with a ten foot pole. Electrical work is so closely inspected out here, it is not worth trying the diy route. A mistake is going to be looked at as arson. It costs me dearly to stick to long held work ethics.
mj12 is offline   Reply With Quote
Old 02-16-2014, 12:44 PM   #19
Rewards Points: 582
good point...here in pa its not that closely looked at..however it is closely looked at when work is done and needs inspected they are tough no matter what the cost...and rightly so ..thanks ben sr
Old 02-16-2014, 12:51 PM   #20
Rewards Points: 582
Originally Posted by digitalplumber View Post
Ben I applaud your ethics, coupla questions:
Other than the drops, was the other work done correctly
Is she a senior needing a break, one of course that wont burn her house down?
everything else seems to be ok she is not a senior ..if she was and needed abreak ..I have small programs in place in my company for that purpose....only reason I see why panel was changed was because box was full and adding a/c there would have been no room....elect stove, elect dryer, elect water tank...well pump.. 6-10 single breakers....see what i mean ..thanks ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
digitalplumber (02-16-2014)
Old 02-16-2014, 12:55 PM   #21
Rewards Points: 3,396
Well being "licensed" and registered.................
If there are issues which I would be liable for, as not to over extend myself..I would and have walked away from jobs....
Being registered.... It's how you feel about running your company and what responsibilities you are willing to assume.
ritelec is offline   Reply With Quote
Upgrade to a 40 slot 200a panel tommyxv Electrical 9 08-07-2013 08:25 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Upgrade panel, add subpanel, add tandem breakers? oregondiy Electrical 11 12-30-2010 10:45 PM
Breaker panel upgrade Jim Patton Electrical 2 11-04-2010 08:47 AM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
