Panel To Stove ,not Full Pwr ? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 06:53 PM   #1
Panel to stove ,not full pwr ?
Hey there,,old wiring removed, from stove to panel,,,new installed, correct gauge, 40am breaker.... Continuity checks . wiring checks,,,yet not full pwr on news stove...light works on top and stove,,warming burner works,,, I do have 110 on both side of incoming receptcle,,perplexed......???get back ,,thxs Kevin
Kevin@cntrls is offline   Reply With Quote
Old 11-30-2010, 07:09 PM   #2
Electrician
Do you have 240V between them?
VersaBar is offline   Reply With Quote
Old 11-30-2010, 09:29 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Any chance did you have GE breakers aka 1 inch twinner or skinny breakers if that the case you will have to move it up or down half width to get it full.
If not check the voltage between red et black conductors you should get full 240 volts if reading zero volts between the two that mean you have to check the breaker to verify it.
And where did you read the voltage from ?? at the breaker or at the recepectale ??
Merci,
Marc
Panel full, was wondering what options were ibjames Electrical 30 10-13-2010 05:32 PM
New Dishwasher...panel is full!!! hellothere123 Electrical 10 09-19-2010 11:34 AM
Panel cleanup gdoucette Electrical 5 06-26-2010 02:01 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
100A Panel is full...I Need more circuits redly Electrical 2 06-20-2005 06:26 AM
