Panel Lug Nuts And Torque - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Jim Port
  • 1 Post By Fishbulb28
Old 04-08-2019, 10:51 PM   #1
Rewards Points: 253
Panel Lug Nuts and Torque
I'm trying to get the torque right on some power/neutral/ground lugs because I'm a nerd. They are the flathead type and the nut in the lugs are close to 3/4" in diameter and the spec states 50 in-lb of torque. I put my regular flathead bit in my in-lb torque wrench and the head of the bit wasn't large enough so it stripped out the lug nut a bit since they are made of soft aluminum.
Can an electrician tell me if they sell special bits for these large lug nuts and how they go about torquing them to spec? Or am I just a square for trying to torque these down to spec?
seephor is offline   Reply With Quote
Old 04-09-2019, 05:03 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 2,084
Re: Panel Lug Nuts and Torque
Where are these screws located? On breakers? In the panel? Do you have a picture you can share so we can see what you see?
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 04-09-2019, 10:31 PM   #3
Licensed electrician
Rewards Points: 3,592
Most of the larger connections are Allen screws to avoid being stripped.
The code calls for properly torquing connections including device screws.
J. V. likes this.
Old 04-10-2019, 12:30 PM   #4
Rewards Points: 438
I tighten all the lugs I have ever touched as tight as they will turn and then stop. That is more than enough to help the properly sized cable in the lug. Tighten the screw until it stops turning
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is offline   Reply With Quote
Old 04-10-2019, 12:41 PM   #5
Rewards Points: 843
Andrew
Andy.....you might want to read this.....
https://www.ecmweb.com/contractor/do...calibrated-arm
DanS26 is offline   Reply With Quote
Old 04-10-2019, 12:46 PM   #6
Oso954's Avatar
Rewards Points: 1,190
Thatís severe over-tightening when they are specíd at 50 inch lbs. (4.17 ft lbs)
Oso954 is offline   Reply With Quote
Old 04-10-2019, 01:57 PM   #7
Rewards Points: 438
It may be, but they are still tight to this day. I am referring to buildings I wired some 40 years ago.
Andrew
Old 04-10-2019, 08:29 PM   #8
Andrew
A total hack method. I guess you have never seen the damage caused from overheated connections from being too tight or conductors flattened or cut from improper torque like you advocate.
Old 04-11-2019, 04:07 PM   #9
Rewards Points: 253
The hex or allen type ones are easy since I can use my hex key sockets with my torque wrench but these regular flat head ones that are 1/2"+ in diameter are the ones I can't find any socket type of flathead fits that have a wide enough flat head to prevent it from stripping out. I figured someone must sell some 1/2" wide flat head socket bits but I can't come across any. I used a regular 1/4" drive impact bit but the head is not wide enough so it strips out the soft AL. I ended up just use a large screwdriver and torqued it by feel but I'd rather proper torque it with my torque wrench..
Old 04-11-2019, 08:57 PM   #10
Rewards Points: 1,230
Get one of these and a torque wrench.....
curiousB is online now   Reply With Quote
Old 04-11-2019, 10:37 PM   #11
Disrespectful to dirt
Fishbulb28's Avatar
Rewards Points: 1,938
What you're looking for is called a drag link socket.
The only retail stores I've seen them in were Sears stores with a full tool selection. I'm not sure if any Sears still in existence stocks much in the way of oddball tools, none of the last ones around here did. So it's probably going to be found at a specialty tool shop or ordered online.
mx13 likes this.
Fishbulb28 is online now   Reply With Quote
Old 04-11-2019, 11:43 PM   #12
Rewards Points: 253
Perfect. I would have never guessed “drag link socket” This is exactly what I’m looking for. I’ll order online. Thanks!
150 ft lbs of torque for a lugnut Bigplanz Automotive Repairs 16 12-31-2016 08:32 AM
How much torque to use on deck bolts? Deck Carpentry 12 07-31-2016 09:11 AM
Torque Wrench with or without case? Solidify Automotive Repairs 19 03-07-2015 11:20 PM
Main Electric Panel Help Redrum Ninja Electrical 13 10-22-2011 07:28 PM
hold the nuts! (wire nuts that is) analogmusicman Electrical 6 05-25-2008 11:34 AM
