DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Panel Lug Nuts and Torque (https://www.diychatroom.com/f18/panel-lug-nuts-torque-656977/)
seephor 04-08-2019 10:51 PM
I'm trying to get the torque right on some power/neutral/ground lugs because I'm a nerd. They are the flathead type and the nut in the lugs are close to 3/4" in diameter and the spec states 50 in-lb of torque. I put my regular flathead bit in my in-lb torque wrench and the head of the bit wasn't large enough so it stripped out the lug nut a bit since they are made of soft aluminum.
Can an electrician tell me if they sell special bits for these large lug nuts and how they go about torquing them to spec? Or am I just a square for trying to torque these down to spec?
chandler48 04-09-2019 05:03 AM
Re: Panel Lug Nuts and Torque
Where are these screws located? On breakers? In the panel? Do you have a picture you can share so we can see what you see?
Jim Port 04-09-2019 10:31 PM
Most of the larger connections are Allen screws to avoid being stripped.
The code calls for properly torquing connections including device screws.
HandyAndyInNC 04-10-2019 12:30 PM
I tighten all the lugs I have ever touched as tight as they will turn and then stop. That is more than enough to help the properly sized cable in the lug. Tighten the screw until it stops turning
Andrew
Handy Andy In Mt Airy NC
DanS26 04-10-2019 12:41 PM
Andrew
Andy.....you might want to read this.....
https://www.ecmweb.com/contractor/do...calibrated-arm
Oso954 04-10-2019 12:46 PM
Thatís severe over-tightening when they are specíd at 50 inch lbs. (4.17 ft lbs)
HandyAndyInNC 04-10-2019 01:57 PM
It may be, but they are still tight to this day. I am referring to buildings I wired some 40 years ago.
Andrew
Jim Port 04-10-2019 08:29 PM
Andrew
A total hack method. I guess you have never seen the damage caused from overheated connections from being too tight or conductors flattened or cut from improper torque like you advocate.
seephor 04-11-2019 04:07 PM
The hex or allen type ones are easy since I can use my hex key sockets with my torque wrench but these regular flat head ones that are 1/2"+ in diameter are the ones I can't find any socket type of flathead fits that have a wide enough flat head to prevent it from stripping out. I figured someone must sell some 1/2" wide flat head socket bits but I can't come across any. I used a regular 1/4" drive impact bit but the head is not wide enough so it strips out the soft AL. I ended up just use a large screwdriver and torqued it by feel but I'd rather proper torque it with my torque wrench..
curiousB 04-11-2019 08:57 PM
1 Attachment(s)
Get one of these and a torque wrench.....
Fishbulb28 04-11-2019 10:37 PM
What you're looking for is called a drag link socket.
The only retail stores I've seen them in were Sears stores with a full tool selection. I'm not sure if any Sears still in existence stocks much in the way of oddball tools, none of the last ones around here did. So it's probably going to be found at a specialty tool shop or ordered online.
seephor 04-11-2019 11:43 PM
Perfect. I would have never guessed “drag link socket” This is exactly what I’m looking for. I’ll order online. Thanks!
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
