Panasonic Vent Fan Nightlight Wiring? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By LawnGuyLandSparky
  • 1 Post By MrElectricianTV
Old 05-26-2019, 08:21 PM   #1
Rewards Points: 44
I'm retrofitting a Panasonic Whisper fan/light in my bathroom ceiling.
I have two existing wall switches for the fan and 10W LED light circuits, but I'm wondering how best to handle the 1W LED nightlight. I'm going to pull another wire for the nightlight and intend to have it always ON. But to be to code must I add another wall switch just for the nightlight or can it be controlled just by the breaker?
Thanks for any advice.
efrin38 is offline   Reply With Quote
Old 05-26-2019, 09:16 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 894
Re: Panasonic Vent Fan Nightlight Wiring?
No switch required, leaving on is fine.
Sent from my Moto E (4) Plus using Tapatalk
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
efrin38 (05-26-2019)
Old 05-30-2019, 01:56 PM   #3
Rewards Points: 44
Hey guys, followup question on adding an additional wire for my nightlight.
Currently the fan/light is wired with Romex 14/3. If I need one additional conductor should I pull just a single 14g wire or is best practice to pull another Romex (14/2). Run is about 8'.
Thanks.
Old 05-30-2019, 02:14 PM   #4
Rewards Points: 680
You cannot pull one additional wire. You need another 14/2.
efrin38 likes this.
LawnGuyLandSparky is offline   Reply With Quote
Old 05-30-2019, 03:09 PM   #5
Rewards Points: 2,084
Thanks.
I have installed several Panasonic fans. I have used 14/4 Romex, 14/4 BX, or flexible metal conduit to provide the power. In a pinch I have also used 14/2-2 Romex and relabeled the white/red conductor with blue tape. You cannot install a single conductor unless it is in a conduit. Some people install an extra 14/2 cable and just use one conductor.
efrin38 likes this.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 05-30-2019, 03:20 PM   #6
Rewards Points: 44
Okay thanks! I'll use the old 14/3 to pull a new Romex 14/4 and that simplifies everything.
How to clean a smelly dryer vent Scotty8181 HVAC 3 09-23-2016 10:30 PM
Sewer Vent Placement Soffit Concerns ksears91 Plumbing 3 09-18-2016 12:28 PM
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Dryer vent installation Wiscbldr Building & Construction 3 05-04-2011 03:14 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
