Outside Wiring - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-10-2009, 10:48 AM   #16
I was thinkin more along the lines of the 2 conductor stuff, not the separate wire. I know it's more expensive but easier for the DIY'er. That's what I used for my garage 3 conductor #6. Can you get that stuff in smaller sizes like #12?
Salem747 is offline   Reply With Quote
Old 11-10-2009, 10:58 AM   #17
300zx's Avatar
Post
Originally Posted by Scuba_Dave View Post
It must be THWN, rated for wet use
Might be that most THHN is also rated THWN - but make sure
You are on it dave THW-2: Thermoplastic Insulation (usually PVC), Heat Resistant (90C rating), suitable for Wet locations.
THWN-2: Same as THW except Nylon jacket over reduced insulation thickness. Also rated THHN.
THHN: Thermoplastic Insulation (usually PVC), High Heat Resistant (90C rating), dry locations only, Nylon jacket. Also rated THWN.
Key: Suitable for wet locations THWN
Key: Not suitable for wet locations THHN
People think they can run Thhn in coduit in wet locations, but they can't. Unless it has a dual THHN/THWN rating
300zx is offline   Reply With Quote
Old 11-20-2009, 01:20 PM   #18
Great !! I have the 1" conduit's in place and found the THNN/THWN wire from the electrical store (HD and Lowes guy's did not know what THWN stands for).
Do i need to run three of these (12 gauge) wires (red, blue and neutral) in a coduit. How do I color code them ?
indy is offline   Reply With Quote
Old 11-20-2009, 02:37 PM   #19
#12 wire must be the correct colors - they can't be remarked
In the US I use Black, white & green for a normal run
Hot can be red/black or any othe rcolor EXCEPT white or green
Neutral is usually white, but can be grey
Ground must be green
A 2nd hot for a multi-wire branch circuit I use red
If 2 seperate circuits I might use grey for the 2nd neutral
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Cloth Wiring - Replace? JessicaGus Electrical 9 09-23-2009 06:45 PM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
New Home Wiring - Seeking Expert Advice Dirtrnr Electrical 3 02-10-2009 10:33 AM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
