Outlets Under Switches? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 01:30 PM   #1
Outlets under switches?
I have a small bathroom. I was wondering if I can put two switches for lights right above two outlets by the sink (for blowdryer, electric shaver, etc.). Is there a minimum distance that I should keep between the two (stacked) boxes?
You guys are awesome!
RedBear is offline   Reply With Quote
Old 01-13-2010, 01:42 PM   #2
Not entirely sure of your situation, but what you propose seems OK to me as long as it's done in a proper, workman-like way.
oilseal is offline   Reply With Quote
Old 01-13-2010, 01:52 PM   #3
300zx's Avatar
Post
You want to leave a couple of inches between so that the plates fit and if you are using cut-in boxes maybe a little more so you don't break the drywall in between the outlets and switches.
300zx is offline   Reply With Quote
Old 01-13-2010, 01:56 PM   #4
I use a dual switch in a single box
A quad light switch box over a quad outlet box is not going to look good
I would get rid of the dual outlets & put a dual switch in
Old 01-13-2010, 03:13 PM   #5
Got it! Thank you very much!
Replaced outlets, now wall switches don't work? PittsburghPaul Electrical 3 08-09-2009 05:50 PM
Lining up outlets and switches unixb0y Electrical 8 10-03-2008 11:12 AM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 04:10 PM
replacing old outlets and switches Nailpounder Electrical 7 04-28-2008 09:36 AM
15A or 20A switches & outlets MIKEGOUGH1 Electrical 1 03-14-2007 07:04 PM
