Outlets Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2010, 09:54 AM   #1
Rewards Points: 35
Outlets not working
I recently moved into a home (built 1981) and noticed the outlet in the master bath doesn't work. When I went to the spare bath, the same problem existed. I also noticed some of the outlets outside or in the garage don't work. Yesterday, when I was putting up a ceiling fan I noticed that the bathrooms and garage are under one breaker in the panel.
Is it possible the breaker is at fault and is there anything I can try on my own before I call an electrician?
AngeloUCF is offline   Reply With Quote
Old 05-30-2010, 10:17 AM   #2
Master Electrician
Rewards Points: 5,082
The scenario you have described should include a GFCI somewhere, either a circuit breaker or receptacal. Look for a tripped GFCI somewhere.
brric is online now   Reply With Quote
Old 05-30-2010, 10:27 AM   #3
Rewards Points: 35
Thanks, you're exactly right. I did a google search and ended up looking in the garage and found the GFCI. I was surprised to not see them in the bathrooms. Hooray, I can cut my hair without an extension cord!
Three outlets not working after heavy storm yummy mummy Electrical 15 07-06-2012 06:33 PM
outlets not working Tradesman14 Electrical 31 06-29-2009 09:27 PM
some outlets not working Clallen Electrical 5 06-08-2009 04:09 PM
Outlets stopped working RammsteinNicCage Electrical 12 05-03-2009 09:47 PM
Electrical storm - outlets not working SG94 Electrical 4 04-27-2008 09:28 AM
