# Of Outlets In A Bathroom - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-23-2010, 03:59 PM   #16
Red face
Originally Posted by Silk View Post
Don't forget one for the towel warming rack
I don't think that after you walk out of a HOT shower you care very much about the towel being warmed by the rack!!
spark plug is offline   Reply With Quote
Old 04-23-2010, 05:38 PM   #17
I take cool showers in the summer, so a nice warm towel is nice
Plus a towel warmer helps dry the towel off faster
We don't have heat in that bathroom, so the 600w towel heater will keep the room warm
Old 04-24-2010, 07:37 AM   #18
electrician
When the bathroom's cold in the winter you care. I spent some time in Finland/Sweden and they run the hot water through a towel warmer before it gets to the shower. Mine just plugs in. Who's do you think is more economical. If I ever redo my bath I will use the hot water.
Silk is offline   Reply With Quote
Old 04-24-2010, 07:50 AM   #19
Military Mom of 4
Snav's Avatar
News to me - there's a minimum requirement for outlets? Someone please inform Arkansas. I've actually lived in 3 homes that had none - I've had to install them either in with the lighting or in with a switch.
Learn something new everyday.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 04-24-2010, 08:46 PM   #20
Thumbs up
Maybe the inspector/s didn't get to those locations, yet!!
Old 04-24-2010, 09:22 PM   #21
Rewards Points: 1,192
Originally Posted by brric View Post
Double bowl vanities require either one recep between the bowls or two receps, one to serve each bowl.
Can you document your asseration?
bobelectric is offline   Reply With Quote
Old 04-24-2010, 09:27 PM   #22
Do you have a code reference that states something different ?
Old 04-24-2010, 09:38 PM   #23
Master Electrician
Rewards Points: 5,084
I don't have documentation. I know what is enforced in Indiana and Michigan where I work, and the fact a receptacle must be within 3' of the outside edge of the bowl.
brric is online now   Reply With Quote
Old 04-24-2010, 09:43 PM   #24
art.210.8(a)(1)
Art. 445.20
Old 04-24-2010, 10:00 PM   #25
art.210.8(a)(1)
Art. 445.20
NEC 2008
210.8(a)(1) indicates GFCI protection required, I don't think anyone will argue that point
Article 445 is for Generators
I do not see a 445.20
Old 04-24-2010, 10:02 PM   #26
Master Electrician
My book has no 445.20.
Old 04-24-2010, 10:07 PM   #27
assakly. check your N.E.C. 2008 index!
Old 04-24-2010, 10:14 PM   #28
I don't see anything in the index for bathrooms that references 445.20
I guess I'm just wondering what you disagree with ?
That a 2nd outlet is needed...or placement....or ?
Old 04-24-2010, 10:46 PM   #29
Registered User
Rewards Points: 526
I'm not a sparky, but that is really easy to find. You need one within 3' of each sink bowl, unless it is within 3' of both bowls: "It should be noted that while 210.52(D) only requires one 15A or 20A, 125V receptacle within 3 ft of each sink in the bathroom, the requirement in 210.8(A)(1), which calls GFCI protection of receptacles in dwelling unit bathrooms, would apply to all 15A and 20A, 125V receptacles in a dwelling unit bathroom, and GFCI protection must be provided for any such receptacle installed there. When combined with the rule of 406.11, any 15A or 20A, 125V-rated receptacle installed in a dwelling unit bathroom would have to be GFCI protected and be a listed tamper-resistant receptacle." From: http://ecmweb.com/nec/whats_wrong_he...10/index1.html
And: http://books.google.com/books?id=m6R...ticles&f=false
Be safe, Gary
Old 04-24-2010, 11:35 PM   #30
thanks.
bad bathroom fan and wierd outlets Tradesman14 Electrical 6 06-18-2009 01:17 PM
Bathroom electrical outlets dontom Electrical 2 01-07-2009 08:11 AM
Basement finishing : Bathroom and Wetbar Outlets cderner Electrical 8 07-25-2008 06:27 PM
Bathroom Outlets - How far above finished cabinet height? MikeinBurien Electrical 4 12-10-2005 11:11 AM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
