Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2010, 09:57 PM   #1
outlets
how many outlets can you run on a 15 amp breaker using 12-2 wire that will also have 2 110 light fixtures.
spankyjc is offline   Reply With Quote
Old 01-28-2010, 10:11 PM   #2
As many as you want, there isn't a restriction under NEC code
If you are concerned about load run 2 circuits
I never run 15a outlet circuits, only 20a
And I keep lights on different circuits
Just my preference
Old 01-28-2010, 10:21 PM   #3
Rewards Points: 81
Ditto
Chevyman30571 is offline   Reply With Quote
Old 01-29-2010, 02:05 AM   #4
Too Short? Cut it Again!
In this day and age of electronic gadgets and equipment, I think 20amps a good idea too.
Old 01-29-2010, 06:15 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
I know this is a very common mentality, but with today's energy compliance, and the fact that electronic devices draw less now than they ever did, and that electronics draw substantially less than an electro-mechanical counterpart, you'd be surprised how little load is actually present.
Keep in mind I am not talking about things like hair dryers.
Old 01-29-2010, 07:48 AM   #6
I use 20a breaker (same cost as a 15a) & 12-2 wire
To me, you are getting 33% more capacity & it doesn't cost 33% more
Plus the OP is running 12-2 wire
I'd rather have the capacity & not need it, then need it & not have it
Wife's Vac uses 12a, whcih can be used anywhere in the house
With a 15a circuit that only leaves 360w that can be used on the circuit when the Vac runs
Old 01-29-2010, 08:39 AM   #7
I do agree Dave. I was just pointing out about electronic devices.
Old 01-29-2010, 08:53 AM   #8
Ah, I just read Sdesters comment, realized you were responding to that
My computer & monitor do use less power then older models
We replaced a81 cu ft fridge with a 26 cu ft that uses 10% less power
I also opted for an LCD instead of a Plasma (500w) due to power use
My 42" LCD does use more power (120w) then my old 35" CRT (90w)...but not much more & its bigger
And the LCD shuts off all power when its off where the old TV kept drawing power when off
I use a Killawatt meter to test electric use in the house for plug-in items
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
