# Of Outlets On 20 Amp Breaker 12/2 Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree27Likes
Closed Thread
Old 05-12-2019, 01:39 PM   #16
HenryMac's Avatar
Rewards Points: 998
Re: # of outlets on 20 amp breaker 12/2 wire
Originally Posted by brric View Post
People need to post facts about code, not opinions.
That would be great but where is the building OP is asking about located?
Originally Posted by MiataBoy View Post
How many would there be for a commercial/industrial setting ?
All depends on the jurisdictional requirements.
Where are you located..
  • What State,
  • What Country,
  • What County,
  • What City
HenryMac is offline
Old 05-12-2019, 07:50 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 794
Originally Posted by Wiredindallas View Post
Thank you, LGMSparky, someone who finally knows the code! Yes, 180 watts per receptacle, but specific loads may limit that to less number receptacles per circuit. Max is 13, but I would never put that many on 1 circuit in a potential workshop.
Why do you think he is the only one to know the code?
He was the only one to answer.
Based on the original question, it seemed that this was a garage at home and therefore not applicable to the garage at home.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is offline
Old 05-12-2019, 08:25 PM   #18
Deleted Member
Shadow99's Avatar
Rewards Points: 918
In a garage being used for storage how many outlets are accepted on a single line ?
"accepted" ?? Required is in the code, and also a maximum. You only need one. Maximum depends on ... oh, see post below !!!!
Originally Posted by stick\shift View Post
It's a number better answered by trying to anticipate what you will be using in the garage. If it truly is storage only, you could put a large number of receptacles in but why bother if nothing is being plugged in anyway?
Why bother getting up in the morning, Bro ?? Why bother typing an answer that doesn't answer anything ?
The post by stick\shift answered a lot more than you think.
I know the answer to your question, but no one here knows what your question is yet (including me)... Bro !
Is this commercial , residential, required outlets, or maximum outlets ??
Shadow99 is offline
Old 05-13-2019, 06:03 AM   #19
CodeMatters's Avatar
Rewards Points: 6,492
What's that have to do with anything? Every comm/ind is different, with
qty and placement of outlets based on usage of the space.
You should simply put in as many outlets as you expect to need in the
locations you expect to use them. Maybe a couple extra where you're
unsure. Done.
CodeMatters is online now
Old 05-13-2019, 07:59 AM   #20
Rewards Points: 56
The question was simple, but I can rephrase it for you (because you are special), how many outlets do you put on a 12/2 wire with a 20amp breaker, when you don't know what will be used on that line ?
MiataBoy is offline
Old 05-13-2019, 08:31 AM   #21
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
You are going to make a lot of friends here.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is online now
The Following User Says Thank You to rjniles For This Useful Post:
MiataBoy (05-13-2019)
Old 05-13-2019, 08:54 AM   #22
Rewards Points: 56
You seem to be very "emotional", good for you ! The question isn't going to have a specific answer, because the usage is unknown.
MiataBoy is offline
Old 05-13-2019, 09:02 AM   #23
Rewards Points: 5,758
Hi Miata Boy, I've been casually watching this thread to see if anyone could satisfy you with an answer. Although many clear answers have been given none have met your needs. Thus I think you have won and can go away feeling happy.
If there is a different answer you want someone to invent, just post it and all will hit your like button and be done.
Bud
jproffer, rjniles, daveb1 and 2 others like this.
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is online now
Old 05-13-2019, 09:17 AM   #24
jproffer's Avatar
Rewards Points: 282
Whoever told you that is.......well........wrong. As many have said above, in residential, in the US there is no limit per NEC (assuming no local limits, such as in parts of Georgia apparently), and in Canada it's 12 total outlets (which is not just receptacles). So where you got 13............**shrug**.
BUT, in commercial or industrial, it may be different and is beyond my knowledge, but very well within the knowledge of many MANY people on this forum and on this thread. So IF this application is Comm or IND, then OP needs to SAY SO.
And there are a lot of people that "finally know the code" and I don't remember anything about 180 watts per.
I guess next you're going to tell us that all circuits are limited to 80% of OCD rating...?
Bud9051 likes this.
jproffer is offline
Old 05-13-2019, 09:27 AM   #25
Rewards Points: 628
^^^^^^^^^^^ This.
daveb1 is online now
The Following User Says Thank You to daveb1 For This Useful Post:
Old 05-13-2019, 10:10 AM   #26
jproffer's Avatar
Rewards Points: 282
So you intentionally asked a question that "would have no specific answer" because YOU were too vague in the question?
Unfortunately, people usually assume on a DIY/homeowner's forum, that the question will be about residential, so there IS a specific answer, depending on where you live, which you don't bother to say.
Also, unfortunately, many people who've been here longer than 10 posts, and have proven themselves, don't like to be "tested" by trolls like you. SO....poof...be gone. Google it....ask your AHJ (if you know what that is)...ask whoever you want. But if you want answers here, I'd suggest losing the attitude PDQ.
jproffer is offline
Old 05-13-2019, 10:33 AM   #27
Deleted Member
Shadow99's Avatar
Rewards Points: 918
That statement is false.
Shadow99 is offline
Old 05-13-2019, 12:22 PM   #28
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,830
I put 12 on one circuit. IMO, it's not about having something plugged into every one of the receptacles, it's about having the flexibility to plug something wherever you want.
Navane1 likes this.
I tear things down and build them up.
Clutchcargo is offline
Old 05-13-2019, 01:35 PM   #29
hkstroud's Avatar
Rewards Points: 5,772
Well, if you know the answer please tell us.
However, be certain to cite the NEC.
Harold,
The Left Handed Widget Maker
hkstroud is online now
Old 05-13-2019, 02:19 PM   #30
Super Moderator
joed's Avatar
Rewards Points: 23,496
The question has been answered several times. This thread is turning bad. Closed.
joed is online now
The Following User Says Thank You to joed For This Useful Post:
jproffer (05-13-2019)
Closed Thread
Wire size question, 12/2 or 14/2? mjninc Electrical 4 03-02-2017 09:36 AM
Can you use 12 gauge wire on a 15 amp breaker? ponch37300 Electrical 3 05-18-2015 07:43 PM
14 gauge wire, 20 amp breaker? JustChecking Electrical 24 04-16-2015 02:25 PM
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 12:29 PM
12/2 wire vs "heater wire" shtoink Electrical 11 11-23-2008 02:16 PM
