Outlet Wiring Dilemma - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2009, 04:11 PM   #1
Outlet wiring dilemma
I have a standard double 3 prong outlet (wired as one in a series - though I don't know where in the series it fits.) The outlet reportedly worked fine until a short occurred (a clothes iron was pulled from the plug while still on.) The breaker reportedly never tripped. Since then, that outlet and a half dozen others above and below by wall location are not functioning. I removed the shorted outlet and find that there is still a hot black with its paired white and and ground, as well as a line black, white and ground. The load(?) black tests as hot with simple $2 tester when connected with the ground but not when tested with it's white. When a new outlet is attached, the outlet doesn't function.
Can anyone give me an idea how to proceed toward a resolution of my problem?
Thanks in advance,
Mac
Mac McCloskey is offline   Reply With Quote
Old 08-16-2009, 04:18 PM   #2
300zx's Avatar
Post
If you know the way they are running(outlets)Go to the one that is working thats where the problem usualy is. Are the outlets stab-ins or wraped around srews
300zx is offline   Reply With Quote
Old 08-16-2009, 04:35 PM   #3
Upstream/Downstream? outlets n.w.
You [probably] have a broken (fr. continuity) Neutral. As "300zx" (Poster #2) said. Start with the functioning outlet. Test across the leads and Hot to Ground. You'll find the problem in no time. Good Luck! (Now more than ever) Don't Drink and Drive!!!
Last edited by spark plug; 08-18-2009 at 09:44 AM. Reason: Typographical error (Typo)
spark plug is offline   Reply With Quote
Old 08-16-2009, 07:46 PM   #4
Test with an incand. bulb in a socket with pigtails; almost all testers respond to phantom voltages.
Old 08-16-2009, 07:58 PM   #5
Pull all the dead receps and the last working one.
In one of the receps, you have a bad/burned/loose connection where the wires are attached into the back of the receps.
Very common with iron usage.
Also, wrap the wires around the terminals instead of plugging them into the back.
220/221 is offline   Reply With Quote
Old 08-17-2009, 01:27 AM   #6
Thumbs up
The outlet I removed was stab-in installed...haven't checked the others. If they are, can I assume you'd recommend wrapping them instead?
Sadly, I don't know the direction of the run...it's my fiance's home and we don't have any original plans or direct knowledge relating to the construction. I'll check outlets at both ends and see if I can find the problem. Thanks for your help!
Mac
Old 08-17-2009, 01:30 AM   #7
Thumbs up
Originally Posted by spark plug View Post
You [probably] have a broken (fr. continuity) Neutral. As "300zx" (Poster #2) said. Start with the functioning outlet. Test across the leads and Hot to Ground. You'll find the problem in not time. Good Luck! (Now more than ever) Don't Drink and Drive!!!
Thanks for the help...I'll keep working on it.
Mac
Old 08-17-2009, 06:38 PM   #8
Thumbs up
Grea suggestion...thanks!t
Old 08-17-2009, 06:38 PM   #9
Thumbs up
Thanks for the info...much appreciated.
wiring new outdoor outlet off exisint outlet hellothere123 Electrical 2 07-10-2009 09:44 AM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 10:54 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 08:18 AM
