Outlet Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2010, 04:19 PM   #1
mm2
Outlet wiring
I am replacing a standard duplex outlet with a combination outlet/nighlight. The outlet is wired with 4 wires (2 white, 2 black), but the new combination receptacle only needs 2 wires. What do i do with the other wires? thanks
mm2 is offline   Reply With Quote
Old 05-31-2010, 04:32 PM   #2
Mad Scientist
One set of wires (one white, one black) will be the power coming into the box. The other set will be power leaving the box for the next outlet on the circuit. Attach a 6 inch length of black wire to the hot terminal (brass screw) on the new outlet, and a 6 inch length of white wire to the neutral terminal (silver screw) of the new outlet. Next, use wirenuts to attach all the black wires to each other, and all the white wires to each other.
You should also have two ground wires in the box, so the same deal applies. 6" length of bare wire to the ground screw on the new outlet, wirenutted to the two grounds in the box.
McSteve is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Wiring a new outlet advice kennykenny Electrical 19 08-29-2008 10:54 AM
Wiring Sequence on Adding a New Outlet kennykenny Electrical 9 06-09-2008 02:06 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
Wiring an outlet in the garden wackerjr Electrical 8 05-28-2006 08:18 AM
