Outlet Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 10:05 PM   #1
outlet problem
I changed my wall switch to match our newly painted room. The new switch works fine but now 2 of my wall plugs, which I also changed do not work.
All the wires are black going into the switch( 3 in total), so I'm notto sure what is hot or neutral. The old switch had the wires placed in the back of it with 1 wire wrapped around a screw .
When I wired my switch I used the screws instead plugging them into the back like the old one.
dads gt is offline   Reply With Quote
Old 08-09-2010, 10:16 PM   #2
Electrician
Proby's Avatar
Do your receptacles work when the switch is turned on??
If so, you simply mis-wired the switch. I can tell you ways to test it, but it might get confusing so just try the two other combinations and one of them will work.
There are 3 blacks because no neutral is necessary for a switch. The neutral is probably spliced in the back of the box, don't touch it. The 3 black wires are:
Feed In- This is the power coming in.
Feed Out- This is the power going out to the receptacles.
Switch Leg- This is the power that is switched by the switch, this goes up to the light.
How did you connect three wires to the switch using the screws? Did you put two wires under one of the screws, or did you pigtail it?
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-09-2010, 10:31 PM   #3
Thanks for the reply...yes the white wires are at the back....I will not touch them...Actually the way it isworking now...when the switch is on,one outlet will work , the other 2 will not. I play with the wires and all the outlets will work only when the switch is either on or off.
When I wired the switch i used 3 different screws ...I didn"t put 2 wires under one screw.
Old 08-09-2010, 10:32 PM   #4
Electrician
Proby's Avatar
Your switch has 3 different screws? Are you putting a wire on the ground screw??
Old 08-09-2010, 10:59 PM   #5
Just call me Andrew
Rewards Points: 1,032
Maybe it's a 3-way? Is there another switch in the same (or nearby) room that may control these outlets?
Andrew
secutanudu is offline   Reply With Quote
Old 08-09-2010, 11:04 PM   #6
Electrician
Proby's Avatar
I thought that at first, but then I thought that it would be odd for a 3-way to control 3 receptacles. Plus, it would be odd to have a 3-way setup with 3 black wires and the whites spliced in the back of the box.
dads_gt, did you buy a 3-way switch by accident?
Old 08-09-2010, 11:07 PM   #7
Just call me Andrew
I agree.
Andrew
Old 08-10-2010, 09:00 AM   #8
no...these outlets work on there own
I don't think it is a 3 way ...it does have 4 scews...no ground
Proby...I beleive uare right in saying i just miss matched the black wires.
Can u give me an idea on how to test which wire should go where...I have an Amp probe to assist me
thanks
Old 08-10-2010, 10:48 PM   #9
bump...for help
Old 08-11-2010, 07:59 AM   #10
Electrician
Proby's Avatar
There are only 3 wires and there is no way to wire them together that would make a short so just try different configurations.
I would really like to see this switch, can you either take a picture or look up the brand/model and link me to it online?
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 09:46 PM
outlet problem hokie_engineer Electrical 13 03-18-2010 03:55 PM
Bathroom problem Imreced Electrical 6 12-09-2007 11:04 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 10:55 PM
