Outlet Confusion - Electrical - DIY Chatroom Home Improvement Forum
Old 06-13-2019, 04:29 PM   #1
Rewards Points: 42
Outlet confusion
I just replaced a few older kitchen outlets expecting trouble (cynic in me and knowing my past troubles with electrickery) and sure enough I've got myself in trouble. I put in a new one being careful to use the existing pigtails and hooking them up correctly...black to brass screw and white to silver. Now my Sperry tester is telling me that hot and neutral are reversed even though I can see they aren't. The outlets down the line aren't working either although my voltage tester shows that the hot wires have power, the Sperry doesn't indicate anything when I plug it in to see what the fault might be.
What on earth have I done wrong here?
grinner is offline   Reply With Quote
Old 06-13-2019, 05:04 PM   #2
Rewards Points: 2,866
Re: Outlet confusion
If black to brass and white to silver, gnd to gnd, and your tester indicates H & N are reversed, then somewhere upstream the blk and wht wires are crossed. This may have been an existing condition.
LawnGuyLandSparky is online now   Reply With Quote
Old 06-13-2019, 05:08 PM   #3
Rewards Points: 42
I think it was the next outlet upstream. I made the change and switched a white wire from hot to neutral terminal. But the outlets downstream still aren't working.
Old 06-13-2019, 05:12 PM   #4
Licensed electrician
Rewards Points: 3,594
Look for a.tripped gfi.
Old 06-13-2019, 06:55 PM   #5
Rewards Points: 42
It was a loose wire. A neutral had popped free of the wire nut. I was trying to get four strands into the nut and it was a strain.
Old 06-13-2019, 08:26 PM   #6
Sounds like the wirenut was too small.
