Outlet Adapter - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2013, 03:29 PM   #1
Rewards Points: 150
Exclamation
Outlet Adapter
I have a normal 3 prong outlet and wondering if it's safe to plug a non-polarized adapter in to it?
Thank you.
Mijotter is offline   Reply With Quote
Old 10-19-2013, 04:01 PM   #2
Rewards Points: 774
Sure you can, what is it for?
Know A Little is offline   Reply With Quote
Old 10-19-2013, 04:40 PM   #3
Rewards Points: 7,016
Nothing unsafe will happen by plugging an adapter into it. The question is, what are you going to do then?
jeffnc is offline   Reply With Quote
Old 10-19-2013, 04:49 PM   #4
Rewards Points: 150
I had some incandescent rope lighting I wanted to plug in to the adapter.
Old 10-19-2013, 04:51 PM   #5
Interior?
Old 10-19-2013, 04:57 PM   #6
Rewards Points: 150
Yes interior
Old 10-19-2013, 05:05 PM   #7
Should be fine.
Old 10-19-2013, 06:47 PM   #8
Rewards Points: 558
is this what is commonly called a "wall wart"? otherwise what would you need an adapter for?
circuitman is offline   Reply With Quote
Old 10-19-2013, 07:08 PM   #9
It is not a "wall wart". A wall wart converts high power AC current into lower power DC current.
Now that you mention it though, I don't see why a non-polarized plug wouldn't fit into any standard 3 prong outlet.
Old 10-20-2013, 11:33 AM   #10
Rewards Points: 558
exactly my point, when he said adapter that was the first thing that poped into my head. btw they can also have AC outputs.
Old 10-20-2013, 11:50 AM   #11
Rewards Points: 1,216
When I lived in an apartment here in NJ, I was using a polarized and grounded outlet adapter (1 to 3 tap), and was told by the super that I needed to change it to one with an integrated circuit breaker - a power strip. They were having inspections of the units, and that was one of the things people were failing for. So I went to RS and purchased some good surge protectors with circuit breakers. That was fine. I guess they were concerned about overloading. The simple ones don't have any means of limiting current.
FW
Ultrarunner2017 is online now   Reply With Quote
Old 10-20-2013, 03:28 PM   #12
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
FW
That logic makes no sense, just saying.... SOOOOOO, if you have 3 devices plugged in that equal 15 amps, this is bad vs one item that draws 15 amps? See my point?
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Kyle_in_rure (10-20-2013), plummen (10-20-2013)
Old 10-20-2013, 07:00 PM   #13
I don't see a point in it either, but at the time I had no choice other than to replace the tap.
I suppose that some of the residents were stacking the taps so that more than 3 devices could be connected, creating a "rat's nest" of wires. Still, if the breaker is rated at 15A, and the tap is rated at 15A, there shouldn't be any problem, regardless of how many taps and devices are connected.
The real issue is with extension cords, since not all of them are rated for the full 15A (or 20A) the breaker is rated.
FW
Tags
adapter , electirc , outlet , plug , wire
GFI outlet won't reset; voltage at lower terminals--bad outlet? jbeall Electrical 2 06-07-2013 08:52 PM
Outlet has more than 1 breaker linked to it... Mark C Electrical 13 05-28-2013 08:18 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
