Outdoor Receptacle Near Natural Gas Connection? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-22-2014, 01:13 PM   #1
cj133's Avatar
Rewards Points: 318
Outdoor receptacle near natural gas connection?
Hi all,
Installing an outdoor receptacle in a few days and need to know if there are usually any codes restricting how close to a natural gas connection it can be?
The natural gas connection is the quick release type that goes to my Weber grill. The receptacle will be mounted on the side of the porch using UF cable, a water tight connector, GFCI and a hood as per code. The UF cable will be stapled under the porch along the joist until it enters the house.
Though right now I'm a bit annoyed as the box I bought has 5 holes yet they only gave me two plastic plugs so I guess its up to me to figure out what to do with the other 2 I don't need.
The main purpose of this receptacle will be to power a rotisserie which is why I'd prefer it close to the gas connection by the grill. If not, then I'll do what is appropriate as per code, if there is any?
Steam heat pictures.
https://picasaweb.google.com/thetube0a3/Boiler?authkey=Gv1sRgCImUxIqv9436MQ#
1933 GE Monitor Top refrigerator restoration video
http://youtu.be/y2LWjT3e7uQ
cj133 is offline   Reply With Quote
Old 12-22-2014, 04:49 PM   #2
Oso954's Avatar
Rewards Points: 878
I am not aware of any specific code. But there is a gas code requiring that you need 36 inches from the meter or pressure release valves and any ignition source.
As some NG may be released when connecting or disconnecting the gas line, I think it would be prudent to use the same separation.
You may also want to check with your gas company or Building Dept. for any local code amendments that might have a mandated separation.
Oso954 is online now   Reply With Quote
Old 12-22-2014, 04:59 PM   #3
Rewards Points: 3,396
Do you maintain a three foot separation between your gas burners on the stove and your countertop receptacles ? Or water heater. Or dryer. ??
ritelec is offline   Reply With Quote
The Following 2 Users Say Thank You to ritelec For This Useful Post:
joecaption (12-22-2014), Speedy Petey (12-22-2014)
Old 12-22-2014, 05:02 PM   #4
cj133's Avatar
Rewards Points: 318
Wow,
I didn't think of it quite that way. Very good point too!
Old 12-22-2014, 05:16 PM   #5
Oso954's Avatar
Rewards Points: 878
None of those have a quick disconnect. When the quick disconnect is used, it leaks gas from the connection and/or hose.
Some people don't use the disconnect regularly, while others use it for every use of the grill. The risks go up with the frequency of use.
Old 12-22-2014, 05:27 PM   #6
cj133's Avatar
Rewards Points: 318
No,
But a gas stove sure can leak out a ton of gas if the burner blows out from air, or a boiling over pot, or someone bumping the knob when it's off etc.
Old 12-22-2014, 07:30 PM   #7
Oso954's Avatar
Rewards Points: 878
No,
FSD's on modern stoves are designed to prevent that.
Old 12-22-2014, 08:52 PM   #8
cj133's Avatar
Rewards Points: 318
What's an FSD?
We have a $1200 2011 Kitchenaid that the burners can blow out on, or just leak if you bump a knob. Perhaps something has changed since then, I donno?
Old 12-22-2014, 08:59 PM   #9
Flame supervision devise...
google is an amazing thang.
Mine is about 10 yrs old.... quite a bit of gas comes out till the tick tick tick finally ignites...
No disrespect Oso954...
What if I have ars gas, any dangers of standing next to a receptacle...
Old 12-22-2014, 09:00 PM   #10
cj133's Avatar
Rewards Points: 318
Hmm,
Wonder why my stove doesn't have one? At least I don't think it does?
Old 12-22-2014, 09:04 PM   #11
cj133's Avatar
Rewards Points: 318
Just watched a video.
Our's is nothing like that, you push the knob in, turn it to light, it lights you move it to wherever, just like any other gas stove I've used in the past 30 years.
The FSD seems kinda nice, and annoying at the same time judging by the videos.
fix broken condensation line connection duhtroll HVAC 3 11-28-2014 06:57 PM
Dripping washing machine connection icespide Plumbing 4 11-11-2010 09:41 PM
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 03:38 PM
Natural stone veneer Jer General DIY Discussions 7 02-03-2009 01:33 PM
converting propane boiler to natural gas drewhart HVAC 25 01-15-2009 06:23 AM
